I would to know if there is a Windows installer built with OpenMP
support, the need is to use v.surf.rst parallelization (nprocs) to
produce a DTM using (without this support, only one cpu core out of
48).
Neither osgeo4w's build or wingrass is compiled with it, is it due to a
platform instability ? If no build is available, which linux
distribution has grass' package with this support (will use a live usb
then) ?
48).
then) ?
I'm not aware of any OpenMP enabled winGRASS builds. AFAIK it was never
tested enough to provide such winGRASS binaries.
