Hi
First
I noticed that my .bash_aliases is not affected when GRASS starts. I have a .grass.bashrc which is almost the same as the regular one. I want to have only one aliases-file therefore I don't want to copy the aliases in the .grass.bashrc.
in the Init.sh in line 939 the test is
echo "test -r ~/.alias && . ~/.alias" >> "$bashrc"
but the aliases files name which the bash suggests to use is .bash_aliases
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
My solution to get all my aliases is to change the Init.sh every time I update my svn in line 948 where I insert the following lines:
if [ -r "$USERHOME/.bash_aliases" ]
then
cat "$USERHOME/.bash_aliases" >> "$bashrc"
fi
Is there another way?
Maybe somebody may change the Init.sh for better acting
Second
I like to start GRASS with TclTk cause its very useful to have the selection dialog instead of using the long-winded way through grass --text.
But, cause I work most of the time in the shell, every start I first have to close the g.gui / gis.m - monitors
It may be nice to have an option to start GRASS in a mixture between Text and GUI.
My personal solution is to add "echo" in the Init.sh in line 803
# Check for tcltk interface
tcltk | gis.m)
if [ "$osxaqua" ] ; then
echo "$GISBASE/scripts/gis.m" | sh &
else
fi
cheers
Philipp
