Dear grass users,
in wingrass 6.4.1 (or at least on my machine), processing of batch files with grass commands stops after executing v.db.addtable, v.db.addcol, v.db.addcol, v.db.dropcol and their db.* equivalents. The rest of the batch file will not be processed. Of course, there is a workaround using SQL commands with db.execute, but this is substantially more typing work. Anybody has the same problem and knows how to fix it?
Matthias
___________________________________________________________
Empfehlen Sie WEB.DE DSL Ihren Freunden und Bekannten und wir
belohnen Sie mit bis zu 100,- Euro! https://freundschaftswerbung.web.de
On Sat, Mar 12, 2011 at 5:48 PM, Matthias Klingel
<matthias.klingel@web.de> wrote:
Dear grass users,
Do you use the DBF driver? Perhaps you are hit by this bug:
http://trac.osgeo.org/grass/ticket/1308
Hopefully solved soon...
Dear grass users,
For the record:
solved in GRASS 6.4.1 which has been published now.
