[GRASS-user] Batch Processing in GRASS 6.2 w/ Cygwin
I am trying to write a batch file for Cygwin that will run multiple GRASS r.le.pixel commands, change the region, and rerun commands on the new region. I have a simplified version based on a previous posting to this listserv. I have tried using it under #!/bin/sh and #!/bin/ash and receive error with both. Please help. Thank you.
Under #!/bin/sh - Does not produce the testing.txt file
$ ./batch-grass6v3.sh
: No such file or directory4: testing.txt
: No such file or directory5: testing.txt
: No such file or directory6: testing.txt
': not a valid identifier 21: export: GISBASE ': not a valid identifier 22: export: GISRC
./batch-grass6v3.sh: line 25: $‘g.version\r’: command not found
/etc/clean_temp: No such file or directoryrass-6.2.2
Under #!/bin/ash
Produces the testing.txt file but nothing else.
export: Files/ATI: bad variable name
g.version: not found
Here is the current version of the script:
#!/bin/sh
Customize this:
Nothing to change below (I think)
Usage Message
GISRC=“~/testing.txt”
GISDBASE=“/cygdrive/c/Data/WBEA”
GISBASE=“/usr/local/grass-6.2.2”
generate GRASS settings file:
the file contains the GRASS variables which define the LOCATION etc.
echo $GISDBASE > testing.txt
echo “LOCATION_NAME: newset” >> testing.txt
echo “MAPSET: C1” >> testing.txt
exports
export LOCATION_NAME=newset
export GISBASE
export GISRC
export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
export GIS_LOCK=$$ # use PID as lock file number
g.version
Cleanup and Exit
$GISBASE/etc/clean_temp # GRASS’ cleanup routine
rm -rf /cygdrive/c/cygwin/tmp/grass6-$USER-$GIS_LOCK # remove session tmp directory
rm -f $GISRC
Steve Hanser
Wildlife Biologist / GIS Specialist
USGS, FRESC, Snake River Field Station
970 Lusk St. Boise, ID 83706
PH: 208-426-2892 FAX: 208-426-5210
': not a valid identifier 21: export: `GISBASE
': not a valid identifier 22: export: `GISRC
./batch-grass6v3.sh: line 25: $'g.version\r': command not found
Your script appears to be using CRLF line termination; you need to use
LF (the CR will be treated literally, causing all kinds of errors).
This rules out using Notepad to edit scripts. Cygwin has packages for
vim, emacs and xemacs.
Under #!/bin/ash
GISRC="~/testing.txt"
The ~ character isn't expanded inside quotes. Use $HOME instead, i.e.:
  GISRC="$HOME/testing.txt"
I suggest adding quotes here, i.e.
  echo "$GISDBASE" > testing.txt
I strongly suggest adding quotes here. This is probably where the
"Files/ATI" comes from (i.e. /cygdrive/c/Program Files/ATI gets split
at the space between Program and Files).
I need more help. I implemented the suggestions from Glynn and edited the file in emacs. I no longer receive any error messages but the script does not run any GRASS processes. Here is the current version of the script. Obviously I am new to this so I appreciate any help I can get. I have about 100 processes to complete and a batch script is the only way I think I’ll get it done. Thank you.
#!/bin/sh
#customize this:
GISRC=“$HOME/.grassrc6”
GISBASE=“/cygdrive/c/cygwin/usr/local/grass-6.2.2”
Generate Grass settings:
echo “GISDBASE: $GISDBASE
MAPSET: PERMANENT” > $HOME/.grassrc6
Exports
export LD_LIBRARY_PATH=/cygdrive/c/cygwin/lib:$GISBASE/lib:$LD_LIBRARY_PATH
export GISRC=$HOME/.grassrc6
export PATH=“$PATH:$GISBASE/bin:$GISBASE/scripts”
export GIS_LOCK=$$
r.le.pixel map=bigsage sam=m att=b4 te1=m7 te2=t1,t2 edg=e1
CleanupandExit
rm -f $GISRC
Steve Hanser
Steve Hanser
08/08/2007 02:05 PM
To
Steve Hanser <shanser@usgs.gov>
cc
grassuser@grass.itc.it
Subject
Re: [GRASS-user] Batch Processing in GRASS 6.2 w/ Cygwin
> ': not a valid identifier 21: export: GISBASE > ': not a valid identifier 22: export: GISRC
> Under #!/bin/ash
I'll get it done. Thank you.
If you just need to script GRASS commands, it's easier to just run a
script from within a GRASS session than to script the creation of the
session.
GISBASE="/cygdrive/c/cygwin/usr/local/grass-6.2.2"
This probably won't harm anything, but it's better to use Cygwin
pathnames for files and directories within the Cygwin hierarchy, i.e.:
  GISBASE="/usr/local/grass-6.2.2"
# Generate Grass settings:
echo "GISDBASE: $GISDBASE
MAPSET: PERMANENT" > $HOME/.grassrc6
Multi-line strings aren't robust; it's better to use either a
here-document:
  cat > "$HOME/.grassrc6" <<-EOF
  GISDBASE: $GISDBASE
  MAPSET: PERMANENT
  EOF
or a subshell:
  echo "GISDBASE: $GISDBASE"
  echo "LOCATION_NAME: newset"
  echo "MAPSET: PERMANENT"
  ) > "$HOME/.grassrc6"
or multiple commands appending to the file:
  echo "GISDBASE: $GISDBASE" > "$HOME/.grassrc6"
  echo "LOCATION_NAME: newset" >> "$HOME/.grassrc6"
  echo "MAPSET: PERMANENT" >> "$HOME/.grassrc6"
LD_LIBRARY_PATH is specific to Linux and SunOS/Solaris. Windows
(including Cygwin) uses PATH to located DLLs:
  export PATH="$GISBASE/lib:$PATH"
[Cygwin's DLLs are in its "bin" directory, which will already be in $PATH.]
It's probably the fact that $GISBASE/lib is missing from $PATH that's
preventing your script from working. If a Cygwin binary cannot find
its DLLs, it simply terminates without error.
FWIW,
TextPad is a nice editor for Windows which lets you choose newline
format when you Save As..
nedit is a nice editor for UNIX that will run in Cygwin. (there's a pkg)
It also lets you choose newline format.
Hamish
