Hello all.
I see that in 6.7 there is a v.vect.stats function which I would like to use. However, I am running 6.4.2 and don’t want to install 6.7 (again).
Anyone knows what was done before? v.to.rast of points and then v.rast.stats?
Martin
Hello all.
Martin
On Mon, Oct 8, 2012 at 10:45 AM, Martin Album Ytre-Eide
<Martin.Album.Ytre-Eide@nrpa.no> wrote:
Hello all.
[you mean GRASS 7.scvn]
use. However, I am running 6.4.2 and don't want to install 6.7 (again).
You can install v.vect.stats via the extension manager in GRASS 6.
Thanks!
I ment GRASS 7
g.extention extention=v.vect.stats
worked very well.
Martin
________________________________________
Fra: neteler.osgeo@gmail.com [neteler.osgeo@gmail.com] på vegne av Markus Neteler [neteler@osgeo.org]
Sendt: 8. oktober 2012 11:30
To: Martin Album Ytre-Eide
Cc: grass-user@lists.osgeo.org
Emne: Re: [GRASS-user] before v.vect.stats
Hello all.
