Running 7.5.svn (r71933) on Slackware-14.2. Using g.remove without the
'-f' option to check which files would be removed does not find the same
files found by g.list:
The following data base element files would be deleted:
WARNING: No data base element files found
[Raster MASK present]
Is this a user error?
In which mapset are the maps found by g.list. AFAIR, g.remove only lists those files that are in the current mapset as the user can only remove files there.
files there.
Moritz,
Yes, I had forgotten this, as Vero pointed out.
As a suggestion, would it be difficult to append mapset names to map names
for all files, not only duplicates? It would be really helpful to see in
which mapset a map is located, especially when cleaning up from multiple
trials, each having a different map name.
