I am looking for advice on how to manage my locations. I have Grass installed on my laptop, where I'm the only user. So I use the PERMANENT mapset for each location, which seems to be ok.
However, I've got a growing list of locations that is becoming hard to manage. Each dataset that I download becomes its own location, and then these locations start to get mixed up as I import layers from one location to the other, or create new locations to reproject the original data.
I also deal with a lot of point location data, which gets imported into a lat-long location, then exported out to various other locations. Which introduces a new set of transformations to keep track of.
It's all getting to be a bit confusing. I suspect more experienced users must have developed useful guidelines for managing their own datasets? I hope it's not off-topic to solicit your suggestions here?
Thanks for your time!
Tyler
My method is to make each LOCATION = a coordinate reference system, then each MAPSET holds all layers for some project. So I have a LOCATION called WGS84, and inside several MAPSETs, one for each project. Then another LOCATION called ITM (Israel transverse Mercator) again with several MAPSETs inside. There are cases where I have data for a certain project in two CRS’s so I’ll have two MAPSET’s with identical names in both LOCATIONs.
Works for me…
On 27-Apr-14 7:11 PM, Tyler Smith wrote:
I am looking for advice on how to manage my locations. I have Grass installed on my laptop, where I’m the only user. So I use the PERMANENT mapset for each location, which seems to be ok.
However, I’ve got a growing list of locations that is becoming hard to manage. Each dataset that I download becomes its own location, and then these locations start to get mixed up as I import layers from one location to the other, or create new locations to reproject the original data.
It’s all getting to be a bit confusing. I suspect more experienced users must have developed useful guidelines for managing their own datasets? I hope it’s not off-topic to solicit your suggestions here?
Tyler
grass-user mailing list
grass-user@lists.osgeo.org
This mail was received via Mail-SeCure System.
Yes, in my group we have a similar concept. The /grassdata/ directory
is on a shared network drive (NFS in our case).
In our projection based LOCATIONs, the MAPSET names are usually
- project names, or
- user surnames (= mapset owner, so they have their personal playground), or
- dataset name in case of larger datasets (MODIS or ECAD time series
with > 10,000 maps)
Works pretty well.
Added to
http://grasswiki.osgeo.org/wiki/Location_and_Mapsets#Best_practice_examples
There are cases where I have data for a certain project in two CRS's
so I'll have two MAPSET's with identical names in both LOCATIONs.
Works for me...
Similar here.
Best
Thanks both for your suggestions. That gives me a start in rationalizing my sprawling location tree!
Tyler
