[GRASS-user] bitpattern analysis
Laura Poggio wrote:
I am trying to use the QA information of MODIS products. I
found that this analysis can be done in GRASS with
r.bitpattern (from Neteler, 2005 with some examples)
or with r.mapcalc .
From what I understood, the use of r.mapcal seems to be
more flexible. I am just wondering if there are some code
examples using the bitwise operators of mapcalc.
this doesn't answer your question directly, but maybe it is of
interest:
  http://grass.osgeo.org/wiki/MODIS
and quality layer application method here
  http://grass.osgeo.org/wiki/AVHRR
Hamish
Thank you for the links that helped to understand more how the things are working within GRASS.
For the moment I decided to use
r.mapcalc QA_field1=“(QA>>bit_position_field1)% bit_length_field1”
for the different fields and then combining the files obtained into a mask.
Thanks
Laura
2009/6/15 Hamish <hamish_b@yahoo.com>
or with r.mapcalc .
this doesn’t answer your question directly, but maybe it is of
interest:
Hamish
From what I understood, the use of r.mapcal seems to be more flexible.
I am just wondering if there are some code examples using the bitwise
operators of mapcalc. I found the following code:
“lst_filt = (lstmap ~ [XX XX XX 00]) || (lstmap ~ [XX XX 0X 01])”
but to me it is not really clear how this works, especially compared
to the code provided (and explained) by Glynn Clements:
r.mapcalc MASK=“if((sur_refl_qc_250 / 16) % 16 == 11 , 1, null())”
Thank you very much for any help.
Laura
2009/6/15 Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
Hi Laura!
I am sending you some notes of mine off-list. Also, check…
“In the upcoming release of GRASS (version 7) there is an extra module
to derive such quality layers called i.modis.qc” ;
Yann Chemin, International Rice Research Institute, The Philippines,
http://svn.osgeo.org/grass/grass/trunk/imagery/i.modis.qc/i.modis.qc.html
Regards, Nikos
