[GRASS-user] break lines in intersection (rather category problem)
Hi!
Problems may seems simple but isn't
In a simple way (this is only one step there are lots of steps in the loop): I have two lines with same category in separate file. I patch them and make v.clean to braak them in the crossing point. Now I have four lines with same category. I need to load lenghts of every lines to database, (v.to.db) but:
- if I add table and load its length I have sumarrised length of 4 lines
- if I add new categories on another layer I have no way to join information about its previous category
So I need new category for every new line to have records in database to read its length. And I need the old category as atrribute (something like second layer in v.to.points result)
Any help???
Jarek
