[GRASS-user] broken d.mon
Friends,
    I have broken my copy of GRASS 6.4.3. Impressed with the GRASS70 display, I foolishly tried
d.mon wx0
in GRASS64. It not only did not display, now no monitors exist, i.e.
GRASS 6.4.3 > d.mon -l
      no known monitors
It has affected all my locations, not just the one where I issued the command, so I don't think the change is in my PERMANENT.
    I looked through previous discussions of d.mon and X0, but they don't seem relevant to this problem.
Thanks, Dave
David W. Roberts office 406-994-4548
Professor and Head FAX 406-994-3190
Department of Ecology email droberts@montana.edu
Montana State University
Bozeman, MT 59717-3460
2014-02-21 17:10 GMT+01:00 Dave Roberts <dvrbts@ecology.msu.montana.edu>:
d.mon wx0
this is not possible in G6. Here d.mon works with X-based monitors,
ie. d.mon x0.
Martin
Hi Martin,
    Thanks. I do understand that. But now I have no X monitors (nor png or anything else for that matter).
Dave
On 02/21/2014 09:18 AM, Martin Landa wrote:
2014-02-21 17:10 GMT+01:00 Dave Roberts<dvrbts@ecology.msu.montana.edu>:
d.mon wx0
ie. d.mon x0.
Martin
What happens if you write
d.mon x0
Note that X monitors does not work on MS Windows.
On Fri, Feb 21, 2014 at 12:17 PM, Dave Roberts <dvrbts@ecology.msu.montana.edu> wrote:
Hi Martin,
Dave
d.mon wx0
ie. d.mon x0.
Martin
Department of Ecology email [droberts@montana.edu](mailto:droberts@montana.edu)
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Hi Dave,
let's keep the conversation on list. I hope you don't mind.
On Fri, Feb 21, 2014 at 2:57 PM, Dave Roberts <
Hi Vaclav,
    Thanks for your help. I'm running Scientific Linux 6 (EL6-based).
when I enter d.mon x0 it says there is no such monitor.
Isn't there some problem with compilation? I'm not sure if this is even
possible but maybe compilation can be set in the way that no monitors are
included.
The command
d.mon -l
generates
no known monitors
Hm, now I understand what you are saying, -l behavior differs for 6 and 7.
http://grass.osgeo.org/grass64/manuals/d.mon.html
http://grass.osgeo.org/grass70/manuals/d.mon.html
So, no x0-9, no png, no nothing.
Thanks, Dave
d.mon x0
<dvrbts@ecology.msu.montana.edu <mailto:dvrbts@ecology.msu.montana.edu>>
wrote:
    Hi Martin,
    Dave
        Roberts<dvrbts@ecology.msu.__montana.edu
        <mailto:dvrbts@ecology.msu.montana.edu>>:
            d.mon wx0
            exist, i.e.
monitors,
        ie. d.mon x0.
        Martin
    ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~~~~~~~~~~~~~~~~~
~~__~~~~~~~~~~~~
    406-994-4548 <tel:406-994-4548>
    406-994-3190 <tel:406-994-3190>
    droberts@montana.edu <mailto:droberts@montana.edu>
    _________________________________________________
    grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
    http://lists.osgeo.org/__mailman/listinfo/grass-user
    <http://lists.osgeo.org/mailman/listinfo/grass-user&gt;
Hi Vaclav,
    Happy to stay on list. I'm grateful for all the help I've received here.
    So, the problem is not with compilation. GRASS64 was working well on my system (except for v.dissolve and lib gmath, see other list issues). Oddly, when I mistakenly entered d.mon wx0 it not only didn't work (which should be expected), it disabled all the other monitor options (seemingly permanently). When I changed to another location the problem persisted which really surprised me.
    Fortunately I have other machines to work on, but this is my primary machine for a large research project that emphasized GRASS. I'm in the process of moving to GRASS7, but I couldn't get it to compile on this machine (Markus N is helping me with that), so I stayed with GRASS64.
Thanks, Dave
On 02/21/2014 01:52 PM, Vaclav Petras wrote:
Hi Dave,
wrote:
    Hi Vaclav,
    (EL6-based). when I enter d.mon x0 it says there is no such monitor.
are included.
    The command
    d.mon -l
    generates
    no known monitors
    Thanks, Dave
        d.mon x0
        <dvrbts@ecology.msu.montana.__edu
        <mailto:dvrbts@ecology.msu.__montana.edu
        <mailto:dvrbts@ecology.msu.montana.edu>>>
        wrote:
             Hi Martin,
        monitors
             Dave
                 Roberts<dvrbts@ecology.msu.__m__ontana.edu
        <http://montana.edu>
        <mailto:dvrbts@ecology.msu.montana.edu>>>:
                     d.mon wx0
        monitors
                     exist, i.e.
        X-based monitors,
                 ie. d.mon x0.
                 Martin
        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~____~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~__~~~~~~~~~~~~
        406-994-4548 <tel:406-994-4548> <tel:406-994-4548
        <tel:406-994-4548>>
        406-994-3190 <tel:406-994-3190> <tel:406-994-3190
        <tel:406-994-3190>>
             ___________________________________________________
        <mailto:grass-user@lists.__osgeo.org
        <mailto:grass-user@lists.osgeo.org>>
        http://lists.osgeo.org/____mailman/listinfo/grass-user
        <http://lists.osgeo.org/__mailman/listinfo/grass-user&gt;
        <http://lists.osgeo.org/mailman/listinfo/grass-user&gt;&gt;
    ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~__~~~~~~~~~~~~
On Fri, Feb 21, 2014 at 4:06 PM, Dave Roberts <
Hi Vaclav,
here.
I'm not sure if I'm able to help more. One more thing. What do you have in
`$HOME/.grassrc6`?
I have:
GISDBASE: /.../grassdata
LOCATION_NAME: nc_spm_08
MAPSET: PERMANENT
MONITOR: x0
GRASS_GUI: wxpython
Thanks, Dave
Hi Dave,
wrote:
    Hi Vaclav,
are included.
    The command
    d.mon -l
    generates
    no known monitors
    Thanks, Dave
        d.mon x0
        wrote:
             Hi Martin,
        monitors
             Dave
                     d.mon wx0
        monitors
                     exist, i.e.
        X-based monitors,
                 ie. d.mon x0.
                 Martin
        <tel:406-994-4548>>
        <tel:406-994-3190>>
~~__~~~~~~~~~~~~
Ultimately had to recompile GRASS-6.4.3 to get d.mon to work again. The make generated numerous errors, but much to my surprise make install worked and solved my problem (at least for now).
Dave
wrote:
    Hi Vaclav,
    received here.
in `$HOME/.grassrc6`?
I have:
MAPSET: PERMANENT
MONITOR: x0
GRASS_GUI: wxpython
    Thanks, Dave
        Hi Dave,
        wrote:
             Hi Vaclav,
        such monitor.
        is even
        monitors
        are included.
             The command
             d.mon -l
             generates
             no known monitors
        for 6 and 7.
        http://grass.osgeo.org/__grass64/manuals/d.mon.html
        <http://grass.osgeo.org/grass64/manuals/d.mon.html&gt;
        http://grass.osgeo.org/__grass70/manuals/d.mon.html
        <http://grass.osgeo.org/grass70/manuals/d.mon.html&gt;
             Thanks, Dave
                 d.mon x0
                 <dvrbts@ecology.msu.montana.____edu
        <mailto:dvrbts@ecology.msu.>__m__ontana.edu <http://montana.edu>
        <mailto:dvrbts@ecology.msu.montana.edu>>>>
                 wrote:
                      Hi Martin,
        no X
                 monitors
                      Dave
                          Roberts<dvrbts@ecology.msu.__m____ontana.edu
        <http://m__ontana.edu>
        <mailto:dvrbts@ecology.msu.montana.edu>>>>:
                              d.mon wx0
        now no
                 monitors
                              exist, i.e.
                 X-based monitors,
                          ie. d.mon x0.
                          Martin
        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~______~~~~~~~~~~~~~~~~~~~~~~~~~~__~~__~~__~~~~~~~~~~~~
                      David W. Roberts
           office
        <tel:406-994-4548>> <tel:406-994-4548 <tel:406-994-4548>
                 <tel:406-994-4548 <tel:406-994-4548>>>
                      Professor and Head
              FAX
        <tel:406-994-3190>> <tel:406-994-3190 <tel:406-994-3190>
                 <tel:406-994-3190 <tel:406-994-3190>>>
        <mailto:droberts@montana.edu> <mailto:droberts@montana.edu
        <mailto:droberts@montana.edu>>>
                      _____________________________________________________
        <mailto:grass-user@lists.>__osg__eo.org <http://osgeo.org>
        <mailto:grass-user@lists.osgeo.org>>>
        http://lists.osgeo.org/______mailman/listinfo/grass-user
        <http://lists.osgeo.org/____mailman/listinfo/grass-user&gt;
        <http://lists.osgeo.org/__mailman/listinfo/grass-user&gt;&gt;
        <http://lists.osgeo.org/mailman/listinfo/grass-user&gt;&gt;&gt;
        <tel:406-994-4548>>
        <tel:406-994-3190>>
