Hello all,
I found a small bug in v.db.renamecol
working on dbf- database driver, renaming a column, if (like I made) you try to use a column name greater than 10 characters length, then it gives an error warning, and creates a column with the new name (cut at the end to fit 10 char), but does not fill in the column values, and(!) deletes the old column.
This is: column data is lost!
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www-neu.uni-trier.de/index.php?id=9607
