Is this a bug in the v.buffer function, or do I try to use the buffer function on polygons, which is not possible?
I'm working on WinGRASS 6.4.
Many thanks for any help!
Hello,
I try to create a buffer around a polygon with the following commande:
v.buffer input=… output=… distance=10
I’am using the windows osgeo4w version and the buffer around a polygon works fine even for complex polygons.
By the images it looks like you have overlaping or duplicated boundaries.
Can you send the full command and a image of the vector editing of these polygons?
