there are three levels you have to think of:
first level: geometry; every geometry element has an id number
second level: category; category numbers can point to one or many
geometry ids
third level: database; in tables feature information is stored; every
geometry(group) with a category can be addressed by the same (unique)
numbers in a table with column 'cat'
Its not enough just to make new categories. You have to create the table
with:
db.droptable -f table=yourtable ##if already one exists
v.db.connect -d map=yourtablesmap ##if you want to delete old connections
v.db.addtable map=yourtablesmap ##automatically columns="cat INTEGER"
will be ran and each category of the map gets an entry; default is
layer=1, so categories for layer one will be made; the tables name will
be "yourtablesmap"; for layer=2 "yourtablesmap_2"...
Greets,
Achim
PS:
little script to renew categories
## INPUT:
## $1 vector map with changed features
## $2 layer of changed features
## $3 type of features to change (line,point,boundary,...)
v.category input=$1 output=$1_nocat option=del type=$3
layer=$2 --o
v.category input=$1_nocat output=$1 type=$3 layer=$2 --o
Christian Braun schrieb:
I am using v.net.alloc to create 'catchments' for traffic stations.
Working flawlessly so far...
I see categories with 'v.category resultmap option=report' and it
visualizes also the resultmap with categories.
But if I do a v.info -c on the resultmap I get a warming that no DB
connection is defined. This is the part where I miss the 'new'
information. If I want to go on working with the newly defined
'catchments' I have to export them as Shape or something else and
reimport it again to have the cats in the table.
Is this foreseen like that?
cheers
Christian
Dipl. Geogr. Christian Braun
Tel: +352- 425991-608
Mobil: +49-179-6845896
Mail: christian.braun@tudor.lu
Resource Centre for Environmental Technologies,
Public Research Centre Henri Tudor,
Technoport Schlassgoart,
66 rue de Luxembourg,
P.O. BOX 144,
L-4002 Esch-sur-Alzette, Luxembourg
grass-user mailing list
grass-user@lists.osgeo.org
