Hi everybody, in grass 6.2.1 on fedora 6,
with driver dbf,
I use the command v.overlay (operator=and between 2 polygons maps), and on the output map, all the column with text are transformed on numeric value.
Doesn’t anybody know what happened (is this a pb with the driver dbf) ?
Thanks
with driver dbf,
Doesn't anybody know what happened (is this a pb with the driver dbf) ?
I've been using v.overlay and DBF driver recently in GRASS 6.3 and I
haven't had such problems. Can you be more specific, or at best -
reproduce the problem with Spearfish data?
with driver dbf,
numeric value. Doesn't anybody know what happened (is this a pb with
the driver dbf) ?
column names from map "A" are prefixed by "a_" and column names from map
"B" are prefixed by "b_" ? column types should stay the same.
Sorry everybody, the problem was with the columns of my first input map. When I saw the columns of the output map (after v.overlay) with open office, It was ok but when I use v.db.select to see the dbf table on GRASS, the text value in the CHARACTER columns was remplaced by numeric value (but these values were values of a precedent numeric column).
I make a new test with an input map whose name columns were simplified and it works fine. Maybe the problem was the name of columns (I’ve got a column whose name was b_ALP_ ).
Thanks for your interest and sorry for not testing my problem deeper before asking help from the forum
with driver dbf,
numeric value. Doesn’t anybody know what happened (is this a pb with
the driver dbf) ?
column names from map “A” are prefixed by “a_” and column names from map
“B” are prefixed by “b_” ? column types should stay the same.
