[GRASS-user] bug with projection systems?
I'm wondering if I've stumbled on a bug…
I'm working with a bunch of MODIS data that I've converted to UTM (Zone 36, WGS84) using the Modis Reprojection Tool. Using gdal I can see that these maps have projections of EPSG:32636; however my GRASS location is defined with EPSG:32736. When importing into grass with r.in.gdal, GRASS identifies the two projections as the same and allows me to proceed to import without error. When displaying the maps though, it's obvious that the projections were wrong. It too me a long time to figure this problem out and I'm just wondering if maybe it's a bug?
Thanks!
On Thu, Mar 14, 2013 at 2:57 AM, Shaun Langley <shaunlangley@gmail.com> wrote:
Please post whch GRASS version on which OS you use and
ideally also the command lines + messages to give better help.
(We do similar things and did not meet such problems)
Here is the projection for my input file:
Driver: GTiff/GeoTIFF
Files: MOD112_2004_001.LST_Day_1km.tif
Size is 2495, 2504
Coordinate System is:
PROJCS[“WGS 84 / UTM zone 36N”,
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,33],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“32636”]]
Here is the projection on which I initialized my GRASS location:
Files: Mode_LULC_T1_500m.tif
Size is 1792, 2082
PROJCS[“WGS_1984_UTM_Zone_36S”,
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
PARAMETER[“false_northing”,10000000],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“32736”]]
Here is the projection info from GRASS for my location:
+proj=utm
+south
+no_defs
+zone=36
+a=6378137
+rf=298.257223563
+towgs84=0.000,0.000,0.000
+to_meter=1
Without reprojecting the MODIS image, I can import it into GRASS even though the projection systems don’t match with:
GRASS 6.4.2 (kenya):~/PullDir/0302568977ukjJXB/001 > r.in.gdal input=MOD112_2004_001.LST_Night_1km.tif output=foo.testing
Projection of input dataset and current location appear to match
100%
r.in.gdal complete. Raster map <foo.testing> created.
version: GRASS 6.4.2
OS: MacOS X ML (10.8.2)
Shaun
(sorry for any duplicates, I sent it to the wrong users list)
Shaun Langley
Doctoral Candidate
Department of Geography
Michigan State University
(562) 281-7847
I’m wondering if I’ve stumbled on a bug…
I’m working with a bunch of MODIS data that I’ve converted to UTM (Zone 36, WGS84) using the Modis Reprojection Tool. Using gdal I can see that these maps have projections of EPSG:32636; however my GRASS location is defined with EPSG:32736. When importing into grass with r.in.gdal, GRASS identifies the two projections as the same and allows me to proceed to import without error. When displaying the maps though, it’s obvious that the projections were wrong. It too me a long time to figure this problem out and I’m just wondering if maybe it’s a bug?
JFYI
http://trac.osgeo.org/grass/ticket/1905
Seems that GRASS fails to notice difference between "north" and "south" at all.
Maris.
2013/3/14 Shaun Langley <shaunlangley@gmail.com>:
Size is 2495, 2504
PROJCS["WGS 84 / UTM zone 36N",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",33],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","32636"]]
Size is 1792, 2082
PROJCS["WGS_1984_UTM_Zone_36S",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
    PARAMETER["false_northing",10000000],
    UNIT["metre",1,
    AUTHORITY["EPSG","32736"]]
+proj=utm
+south
+no_defs
+zone=36
+a=6378137
+rf=298.257223563
+to_meter=1
the projection systems don't match with:
100%
Shaun
Shaun Langley
Doctoral Candidate
(562) 281-7847
grass-user mailing list
grass-user@lists.osgeo.org
