I tried to install several add-ons through the command console (g.extension) and they failed,
returning the message
Compiling...
mkdir: cannot create directory `/build': Permission denied
make: ***
[/build/buildd/grass70-7.0/debian/tmp/usr/lib/grass70] Error
1
Where should this directory be created? If I create it will this fix the problem?
Thanks
and they failed,
returning the messageCompiling...
make: ***
1Where should this directory be created? If I create it will this fix the
problem?
It should not install into the system area. Please type at the GRASS
terminal window command prompt:
# this only works if your GRASS 7 is recent:
echo $GRASS_ADDON_BASE
to see how it is defined. I have for example
GRASS 7.0.svn (nc_spm_08_grass7):~ > echo $GRASS_ADDON_BASE
/home/neteler/.grass7/addons
In case it should be defined likewise at your end:
export GRASS_ADDON_BASE=$HOME/.grass7/addons
Perhaps these emails can be helpful (although for GRASS 6):
http://lists.osgeo.org/pipermail/grass-user/2013-February/067077.html
http://lists.osgeo.org/pipermail/grass-user/2013-February/067142.html
