[GRASS-user] Build Grass62!
Hi to everbody, I have some problems while i am compiling grass-6.2.0 stable
version.....
After having launched the ./configure
--with-cxx \
  --with-gdal=/usr/local/bin/gdal-config \
  --with-postgres-includes=/usr/local/pgsql/include \
--with-postgres-libs=/usr/local/pgsql/lib \
  --without-mysql \
--with-sqlite \
  --with-tcltk-includes=/usr/include/tcl8.4 \
  --without-odbc \
  --with-nls \
  --with-motif \
  --with-motif-includes=/usr/include/Xm \
  --without-glw \
  --with-fftw \
--with-readline \
  --with-freetype --with-freetype-includes=/usr/include/freetype2 \
  --enable-largefile \
with config.log:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /home/sam/GRASS&QGIS/grass-6.2.0
Build directory: /home/sam/GRASS&QGIS/grass-6.2.0
Installation directory: /usr/local/grass-6.2.0
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -Wall
-Werror-implicit-function-declaration -fno-common
C++ compiler: c++ -g -Wall
FORTRAN compiler:
Building shared libraries: yes
64bit support: no
OpenGL platform: X11
  NVIZ: yes
  BLAS support: no
  C++ support: yes
  DWG support: no
  FFMPEG support: no
  FFTW support: yes
  FreeType support: yes
  GDAL support: yes
  GLw support: no
  JPEG support: yes
  LAPACK support: no
  Large File Support (LFS): yes
  Motif support: yes
  MySQL support: no
  NLS support: yes
  ODBC support: no
  OGR support: yes
  OpenGL support: yes
  PNG support: yes
  PostgreSQL support: yes
  Python support: no
  Readline support: yes
  SQLite support: yes
  Tcl/Tk support: yes
  TIFF support: yes
  X11 support: yes
$ make
I have this error:
sam@debian:~/GRASS&QGIS/grass-6.2.0$ make
mkdir -p /home/sam/GRASS&QGIS/grass-6.2.0/bin.i686-pc-linux-gnu
/bin/sh: QGIS/grass-6.2.0/bin.i686-pc-linux-gnu: No such file or directory
make: *** [/home/sam/GRASS&QGIS/grass-6.2.0/bin.i686-pc-linux-gnu] Error 127
Can someone explain me the motive?
I use Debian Etch!
View this message in context: http://www.nabble.com/Build-Grass62!-tf2660767.html#a7421558
I don't resolved it, still!
Can someone help me?
View this message in context: http://www.nabble.com/Build-Grass62!-tf2660767.html#a7434367
stable version.....
I have this error:
directory make: ***
remove the the "&" in the "GRASS&QGIS" path name.
"mkdir -p" isn't quoting the path so the & is getting parsed by the
shell. (it thinks everything after the & is a new command)
Hamish
stable version.....
I have this error:
directory make: ***
Hamish
grassuser mailing list
grassuser@grass.itc.it
Thanks for your reply.....
work fine, now
View this message in context: http://www.nabble.com/Build-Grass62!-tf2660767.html#a7438505
That looks like a bug in the Makefile(s); can you say which one(s)?
