[GRASS-user] Building -7.0 Fails
   Running Slackware-14.1 here with Python-2.7.5 and wxPython-2.8.12.1. I
just decided to install -7svn in addition to -6.5svn. The latter continues
to build error-free; the latter fails:
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
  /dev/null | grep -v '</body>\|</html>' > g.gui.timeline.tmp.html
   File
"/home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-linux-gnu/scripts/g.gui.timeline",
line 39, in <module>
     import wx
ImportError: No module named wx
make[1]: *** [g.gui.timeline.tmp.html] Error 1
rm g.gui.timeline.tmp.html
make[1]: Leaving directory
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline'
make: *** [guiscript] Error 2
   There is no error log in the base directory.
   All suggestions on why wx fails to import are certainly welcome.
Rich
Richard B. Shepard, Ph.D. | Have knowledge, will travel.
Applied Ecosystem Services, Inc. |
www.appl-ecosys.com Voice: 503-667-4517 Fax: 503-667-8863
to build error-free; the former fails:
   Correction.
Rich
Rich,
On Fri, Mar 14, 2014 at 8:13 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
'make'.
  File
    import wx
Just to be sure, do you configure with
./configure \
  --with-python \
  --with-wxwidget \
On Fri, Mar 14, 2014 at 3:13 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
‘make’.
/dev/null | grep -v ‘|’ > g.gui.timeline.tmp.html
File
“/home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-linux-gnu/scripts/g.gui.timeline”,
line 39, in
import wx
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline’
only g.gui.timeline does not compile? Or also other g.gui.* modules (g.gui.animation, g.gui.rlisetup,…)? Anyway have you tried to launch grass gui and try to run g.gui.timeline?. This compilation error (if it appears) is usually harmless but I don’t understand why it appears (something wrong with the building environment, not your fault).
Anna
Rich
grass-user mailing list
grass-user@lists.osgeo.org
./configure \
--with-python \
--with-wxwidget \
Markus,
   Yep. I have a configuration file that I have used (successfully) with all
the 6.x sources. Used it on the 7.0 source, too.
./configure --with-postgres --with-sqlite --with-cairo --with-freetype --with-cxx --with-geos=usr/bin/geos-config --with-gdal=/usr/bin/gdal-config --with-python=/usr/bin/python-config --with-wxwidgets=/usr/bin/wx-config --enable-largefile --with-postgres-includes=/usr/local/pgsql/include/ --with-postgres-libs=/usr/local/pgsql/lib/ --with-openmp --with-sqlite-includes=/usr/include/ --with-sqlite-libs=/usr/lib/
Rich
(g.gui.animation, g.gui.rlisetup,...)? Anyway have you tried to launch
appears) is usually harmless but I don't understand why it appears
Anna,
   That's where the build failed. I did not look to see what built
sucessfully before that, nor what would have been built after that.
Rich
On Sat, Mar 15, 2014 at 9:00 AM, Rich Shepard <rshepard@appl-ecosys.com>wrote:
Anna,
After the build of the whole grass (the top most directory in the grass
source code), you should get something like:
Compilation failed. Errors in:
/.../list/of/directories/
/.../where/make/was/not/successful
This you should get when the build fails. In other words, the make always
prints a report at the end with the message whether the compilation was
successful or it prints a list of directories where the compilation failed.
Vaclav
Rich
failed.
Vaclav,
   The tail of that list of directories was what I copied into the original
message. In addition, here's the error.log:
GRASS GIS 7.0.svn 59253 compilation log
Started compilation: Fri Mar 14 08:51:04 PDT 2014
Errors in:
/home/rshepard/GIS/GRASS/grass-7.0svn/scripts/i.pansharpen
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.create
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.support
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.topology
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.info
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.merge
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.remove
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.sample
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.register
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.unregister
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.accumulate
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.accdetect
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.aggregate
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.aggregate.ds
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.colors
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.to.rast3
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.univar
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.mapcalc
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.mapcalc2
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.neighbors
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.series
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.export
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.out.vtk
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.import
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.gapfill
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast.extract
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.extract
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.mapcalc
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.mapcalc2
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rast3d.univar
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.rename
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.select
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.snap
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.shift
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.list
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.db.select
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.export
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.extract
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.mapcalc
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.import
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.what.strds
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.observe.strds
/home/rshepard/GIS/GRASS/grass-7.0svn/temporal/t.vect.univar
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/animation
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/mapswipe
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/gmodeler
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/rlisetup
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/psmap
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/dbmgr
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/vdigit
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/iclass
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/gcp
In case of errors please change into the directory with error and run 'make'.
Finished compilation: Fri Mar 14 08:59:47 PDT 2014
   Mea culpa! I had not looked at the error.log before. Now I see that
nothing in 7.0 is building here.
   Suggestions on where I should start looking for why?
Rich
On Sat, Mar 15, 2014 at 6:24 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
This is relevant since a fail somewhere may cause another later on
(dependencies...).
Errors in:
Please
cd /home/rshepard/GIS/GRASS/grass-7.0svn/scripts/i.pansharpen
make
to see the error.
Likely python-dateutil is not on your system?
(the t.* commands need it. Perhaps to be tested in "configure")
cd /home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/animation
make
the others likewise to see if there is a different error.
same here.
'make'.
... as stated :slight_smile:
Yes.
Best
Markus,
   It is, but an old version. I just upgraded to -2.2 and installed it. I'll
look for other python modules that need upgrading since I upgraded the OS
and it includes python-2.7.5.
   More information when I have it.
Thanks!
Rich
   From ~/GIS/GRASS/grass-7.0svn/gui/wxpython/animation:
File "/home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-linux-gnu/scripts/g.gui.animation",
line 56, in <module>
     import wx
   From ~/GIS/GRASS/grass-7.0svn/gui/wxpython/mapswipe:
   File
"/home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-linux-gnu/scripts/g.gui.mapswipe",
line 51, in <module>
     import wx
   No sense trying the others until I learn why wxPython is not being
imported into the wx namespace.
   Currently have wxPython-2.8.12.1 installed; having issues building
-3.0.0.0.
Rich
On Sat, Mar 15, 2014 at 6:16 PM, Rich Shepard <rshepard@appl-ecosys.com>wrote:
    import wx
  File
    import wx
Please go to the directory of one of the temporal modules and give us the
output of make. Also try if GRASS launches and if it does try launching one
of the gui modules where the build fails. It might happen that the gui
won't start but the grass session should run.
Anna
-3.0.0.0.
Rich
output of make.
Anna,
[rshepard@salmo ~/GIS/GRASS/grass-7.0svn/temporal/t.support]$ make
make: Nothing to be done for irst'.
[rshepard@salmo ~/GIS/GRASS/grass-7.0svn/temporal/t.support]$ cd ../t.create
[rshepard@salmo ~/GIS/GRASS/grass-7.0svn/temporal/t.create]$ make
Also try if GRASS launches and if it does try launching one of the gui
modules where the build fails. It might happen that the gui won't start
   There is no executable file built.
Rich
