I am importing a polygon shapefile and I get this error. The
shapefile was created using QGIS.
v.in.ogr layer=forest_p116r048_repair output=forest_p116r048
dsn=/Users/maning/pfua/map_data/forest_2002_digit/forest_p116r048_p117r047_edited
--o
WARNING: Vector map <forest_p116r048> already exists and will be
overwritten
Projection of input dataset and current location appear to match
overwritten
Layer: forest_p116r048_repair
Importing map 181 features...
WARNING: Area size [7.5e-09], area not imported
Building topology for vector map <forest_p116r048>...
58952 vertices registered
230 primitives registered
Building areas: 100%
225 areas built
225 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built
Number of nodes : 228
Number of primitives: 230
Number of points : 0
Number of lines : 0
Number of boundaries: 230
Number of centroids : 0
Number of areas : 225
Number of isles : 225
Number of incorrect boundaries : 5
Number of areas without centroid : 225
WARNING: Cleaning polygons, result is not guaranteed!
Topology was built
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points 46354
All points (vertices): 58943
Registered points (unique coordinates): 46354
Points marked for break: 345
Breaks: 610
Remove duplicates:
Duplicates: 230
Break boundaries:
Intersections: 39
Remove duplicates:
Duplicates: 7
Clean boundaries at nodes:
Modifications: 0Bus error
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
Hi Maning,
O flyed on your email and saw only warnings, not errors.
It appears to worked.
bests
milton
2009/8/14 maning sambale <emmanuel.sambale@gmail.com>
–o
overwritten
overwritten
Importing map 181 features…
Building topology for vector map <forest_p116r048>…
225 areas built
225 isles built
Topology was built
Number of lines : 0
Topology was built
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Breaks: 610
Remove duplicates:
Duplicates: 230
Break boundaries:
Intersections: 39
Remove duplicates:
Duplicates: 7
cheers,
maning
grass-user mailing list
grass-user@lists.osgeo.org
On Fri, Aug 14, 2009 at 9:39 PM, maning
sambale<emmanuel.sambale@gmail.com> wrote:
There was a vector file but not layers so in effect, there was an error.
On Fri, Aug 14, 2009 at 9:21 PM, Milton Cezar
Ribeiro<miltinho.astronauta@gmail.com> wrote:
Hi Maning,
bests
milton
--o
overwritten
overwritten
225 areas built
225 isles built
Topology was built
Number of lines : 0
Topology was built
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Breaks: 610
Remove duplicates:
Duplicates: 230
Break boundaries:
Intersections: 39
Remove duplicates:
Duplicates: 7
cheers,
maning
cheers,
maning
cheers,
maning
A bus error is usually either an incorrectly aligned memory access or
an attempt to access a memory address not in the process' memory map.
I've mostly seen this when processes run out of stack space.
If the cleaning process uses recursive code, that could be a source of
a stack overflow.
You might check your session limits to see how much stack space is
permitted for each process.
-------------------------> "These thoughts are mine alone!" <---------
Andrew MacIntyre National Licensing and Allocations Branch
tel: +61 2 6219 5356 Inputs to Industry Division
fax: +61 2 6253 3277 Australian Communications & Media Authority
email: andrew.macintyre@acma.gov.au http://www.acma.gov.au/
If you have received this email in error, please notify the sender immediately and erase all copies of the email and any attachments to it. The information contained in this email and any attachments may be private, confidential and legally privileged or the subject of copyright. If you are not the addressee it may be illegal to review, disclose, use, forward, or distribute this email and/or its contents.
Unless otherwise specified, the information in the email and any attachments is intended as a guide only and should not be relied upon as legal or technical advice or regarded as a substitute for legal or technical advice in individual cases. Opinions contained in this email or any of its attachments do not necessarily reflect the opinions of ACMA.
