Paolo,
On Wed, 21 Jun 2006 15:57:30 +0200
Paolo Cavallini <cavallini@faunalia.it> wrote:
Markus Neteler wrote:
> Paolo Cavallini wrote on 06/21/2006 02:50 PM:
>> If they're not executable, I get:
>> Error in startup script: can't find package BWidget 1.2.1
>> while executing
>> "package require -exact BWidget 1.2.1"
>> (file "/usr/lib/grass-6.1.cvs/etc/gm/gm.tcl" line 23)
Just to make things clear, do you mean the tcl files
in /usr/local/grass-6.1.cvs/bwidget ?
I really never have had them executable, and all was fine. Strange.
>> BTW, with latest cvs I get:
>> GRASS 6.1.cvs (Toscana):~ > Error in startup script: can't read
>> "monitor_zooms(1,1,n)": no such variable
>> while executing
> ... no such error here.
The only (unrelated?) error I could spot in ./configure is:
checking whether to use GLw... yes
checking for location of GLw includes...
checking for GL/GLwMDrawA.h... no
checking for X11/GLw/GLwMDrawA.h... no
configure: error: *** Unable to locate GLwM includes.
For the rest, compilation seems to run smoothly, and this is the first
time I see this error.
Any hints?
I don't have this error at ./configure, unless I specify
--with-glw=yes, not having the GLw installed. Please note GLw is not
enabled by default. If you you haven't requested it, the error you
are getting is strange.
I also wonder what we need GLw for in Grass anyway? It's not even
mentioned on http://grass.itc.it/grass60/source/REQUIREMENTS.html nor
in README and INSTALL files. I've never used it.
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
