[GRASS-user] Calculate average of 3 highest values for a set of raster maps
I have a set of 7 raster maps.
I am able to calculate several stats with these mapas using r.series.
Now I need to calculate the mean of the tree highest values of my 7 maps.
Any idea of how can I do that?
cheers
Miltinho - mcr@rc.unesp.br
Laboratório de Ecologia Espacial e Conservação - LEEC
Depto de Ecologia - UNESP - Rio Claro
Av. 24A, 1515- Bela Vista
13506-900 Rio Claro, SP, Brasil
Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
Cel: 19 9853-3220 / 19 9853-5430
Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
PG ECO & BIODIV http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
Hi Milton,
A possible approach could be, for example, to do the following with each map:
r.stats -1 input=map1 output=cellvaluesmap1
It will create a file containing the cell values for each map. Then you can read this file into R and average the three highest values. Something like:
values.map1<-read.table(“cellvaluesmap1”)
threehighest<-values.map1$V1[order(values.map1,decreasing=FALSE)][1:3]
mean3highest<-mean(threehighest)
Hope it helps. Success
Miguel
2013/3/15 Milton Cezar Ribeiro <miltinho.astronauta@gmail.com>
cheers
grass-user mailing list
grass-user@lists.osgeo.org
[apologies for taking the liberty to re-sort previous posts]
Milton Cezar Ribeiro:
map:
like:
values.map1<-read.table("cellvaluesmap1")
If in Linux, there are several ways to do this. One (very) nice approach as
shown in <http://stackoverflow.com/a/3096575/1172302&gt;, could be:
# get the numbers
r.stats -1 input=map1 output=Values1
# sort and keep first 3
sort -rn Values1 | head -3 > Values1.sorted
# sum and divide by 3
echo "( $( paste -sd+ Values1.sorted ) ) / 3" | bc
# or a one-liner!
sort -rn numbers | head -3 | echo "( $( paste -sd+ ) ) / 3" | bc
Other options would be "awk" or "python". Also, note that r.stats has also
the "-x" and "-g" flags. You could grab them as well and, if doing the math
"externally", know where to place the results each time?
However, it seems like a very "resources" hungry approach, if your maps are
many and large. There must be a "smart"(er) way to do this directly using
r.mapcalc...
Best, Nikos
Hi Miltinho
I assume you want the mean of the three highest values for each raster cell? If so, you can do this using another step with r.series
1) If your 7 maps are a1 .. a7:
mapcalc "a1 = 1"; r.mapcalc "a2 = 2"; r.mapcalc "a3 = 3"; r.mapcalc "a4 = 4"; r.mapcalc "a5 = 5"; r.mapcalc "a6 = 6"; r.mapcalc "a7 = 7"
2) calculate the 4/7 quantile. Actually, it should be a little bit smaller to make sure you include your 3rd largest layer. In this example below, 0.57 as approximation is fine
r.series --overwrite input=a1,a2,a3,a4,a5,a6,a7 quantile=0.57 output=res1 method=quantile
2) Next, for all 7 layers, set all values < 4/7 quantile to 0
r.mapcalc "b1 = if(a1>res1,a1,null())"
r.mapcalc "b2 = if(a2>res1,a2,null())"
r.mapcalc "b3 = if(a3>res1,a3,null())"
r.mapcalc "b4 = if(a4>res1,a4,null())"
r.mapcalc "b5 = if(a5>res1,a5,null())"
r.mapcalc "b6 = if(a6>res1,a6,null())"
r.mapcalc "b7 = if(a7>res1,a7,null())"
3) Now, calculate the sum of the 7 new layers
r.series input=b1,b2,b3,b4,b5,b6,b7 method=average output=res2 --overwrite
Your output res2 should have a value 6 for all raster cells.
Paulo
cheers
Sorry, some typo's (but the given code should be ok): set all values < 4/7 quantile to null(), not 0, and you want to calculate the average, not the sum
On Fri 15 Mar 2013 10:05:51 AM CET, Paulo van Breugel wrote:
Hi Miltinho
--overwrite
Paulo
maps.
cheers
Dear all,
Thanks for all replies. I will check it out thoughout the weekend.
Just clarifying something, I need to do the estimations focusing on
each pixels, and not for the full map (I was not that clear before).
Also as my raster maps are very large (~50,000x60,000 pixels) maybe R
(at least on w7) maybe will not handle the seven rasters.
Best wishes
miltinho
2013/3/15, Paulo van Breugel <p.vanbreugel@gmail.com>:
not the sum
Hi Miltinho
--overwrite
Paulo
maps.
cheers
My suggestion does just that, per pixel calculations. And as it is just simple GRASS functions, you should have no problem running it (perhaps a bit of patients depending on your computer).
On Fri, Mar 15, 2013 at 12:13 PM, Milton Cezar Ribeiro <miltinho.astronauta@gmail.com> wrote:
Dear all,
Best wishes
miltinho
Sorry, some typo’s (but the given code should be ok): set all values <
not the sum
Hi Miltinho
  1. If your 7 maps are a1 … a7:
mapcalc “a1 = 1”; r.mapcalc “a2 = 2”; r.mapcalc “a3 = 3”; r.mapcalc
“a4 = 4”; r.mapcalc “a5 = 5”; r.mapcalc “a6 = 6”; r.mapcalc “a7 = 7”
  1. calculate the 4/7 quantile. Actually, it should be a little bit
  1. Next, for all 7 layers, set all values < 4/7 quantile to 0
r.mapcalc “b1 = if(a1>res1,a1,null())”
r.mapcalc “b2 = if(a2>res1,a2,null())”
r.mapcalc “b3 = if(a3>res1,a3,null())”
r.mapcalc “b4 = if(a4>res1,a4,null())”
r.mapcalc “b5 = if(a5>res1,a5,null())”
r.mapcalc “b6 = if(a6>res1,a6,null())”
r.mapcalc “b7 = if(a7>res1,a7,null())”
  1. Now, calculate the sum of the 7 new layers
–overwrite
Paulo
maps.
cheers
Hi Milton,
On Friday 15 Mar 2013 08:13:16 Milton Cezar Ribeiro wrote:
Dear all,
In GRASS7 you can use the RasterRow or RasterRowIO class of pygrass, something
like:
#!python
import numpy as np
from grass.pygrass.raster import RasterRow
from grass.pygrass.gis.region import Region
from grass.pygrass.functions import coor2pixel
# define the list of points that you want
POINTS = [(633042.213884, 226283.771107),
          (641197.93621, 225675.891182),
          (644034.709193, 220711.538462),
          (630028.142589, 224764.071295),
          (630002.814259, 215037.992495), ]
NEIGHS = np.array([(-1, 1),
                   (0, 1),
                   (1, 1),
                   (1, 0),
                   (1, -1),
                   (0, -1),
                   (-1, -1),
                   (-1, 0),
                   (-1, 1)])
def get_neighs(point, region, neighs=NEIGHS):
    res = point - neighs
    valid = ((0 <= res.T[0]) * (res.T[0] < region.rows) *
             (0 <= res.T[1]) * (res.T[1] < region.cols))
    return res[valid]
def do_something(rastname, points, mapset=''):
    # get the current region
    region = Region()
    raster1 = RasterRow(rastname, mapset)
    raster1.open('r')
    # instantiate more raster object here if you need
    average =
    for pnt in points:
        coor = coor2pixel(pnt, region)
        neighs = get_neighs(coor, region)
        sum_ = 0
        for nx, ny in neighs:
            # do something with the neighbour value
            sum_ += raster1[int(nx)][int(ny)]
        average.append(sum_ / len(neighs))
    raster1.close()
    # close the other rasters
    return average
print do_something('elevation', POINTS, mapset='user1')
it's working on North Carolina mapset... maybe I should add get_neighs into
the pygrass.functions module...
whit the same logic you can open more raster at the same time
I've worked with a 10**5x10**5 without problems [0].
Pietro
[0] http://www.mdpi.com/2220-9964/2/1/201
Thanks Pietro and Paulo
I will try all your suggestions.
cheers
milton
2013/3/15, Pietro <peter.zamb@gmail.com>:
Hi Milton,
Dear all,
something
like:
#!python
import numpy as np
                   (0, 1),
                   (1, 1),
                   (1, 0),
                   (1, -1),
                   (0, -1),
                   (-1, -1),
                   (-1, 0),
                   (-1, 1)])
    return res[valid]
    region = Region()
    raster1.open('r')
    average =
    for pnt in points:
        sum_ = 0
    raster1.close()
    return average
Pietro
