Greetings
I need to calculate the average of a set of raster images. How can I calculate it without using mapcalc?
THanks
Kim
Greetings
THanks
Kim
Hi Kim,
You can use r.univar to compute univariate statistics of
your raster data.
http://grass.fbk.eu/grass65/manuals/html65_user/r.univar.html
Daniel.
On Wed, Feb 16, 2011 at 2:31 PM, Kim Besson <kimbesson1981@gmail.com> wrote:
Greetings
THanksKim
grass-user mailing list
grass-user@lists.osgeo.org
Kim:
THanks
Hello Kim,
You can use the module r.series. Like this, if you have few images:
r.series input=image1,image2,image3... method=average output=averaged_image
Or if you have a bunch of images with similar names, you can do:
r.series input="`g.mlist pattern=the_pattern_within_the_ names sep=,`"
Hope this helps.
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Calculate-averagfe-of-raster-maps-without-mapcalc-tp6031736p6032330.html
