I need to assign values to a the cells on the “border” of a raster. The inside and the outside are distinguished by having or not having null values assigned.
I also need to keep the other cell values (internals) untouched.
I thought to use a mapcalc expression like the following (knowing the the external cells have value 9999)
if(A==9999,max(A[1,1],A[1,0],A[1,-1],A[0,-1],A[-1,-1],A[-1,0],A[-1,1],A[0,1]),A)
In this case I’m using max, and I alwasy obtain null values as result, as if nulls (from the cells surrounding the external side of the border) were considered maximum values respect to numeric values (of the internal cells).
I could substiture null values for the external cells with a very low negative value, but I would prefer being able to exlude (or manage somehow) null values in my filter.
Any suggestion?
giovanni
Hey,
Check out r.grow. I am pretty sure you can modify the example given in the manual to find the borders of your raster. Something like:
creates an inverted raster from your raster
r.mapcalc “raster_inverted=if(isnull(raster,1,null())”
grow this inverted raster by one cell
r.grow in=raster_inverted out=raster_inverted_grown
now both rasters overlap at the border, so you can do whatever you want with it, for instance, extract it
r.mapcalc “border=if(raster_inverted_grown==1 && isnull(raster)==0,raster,null())”
Hope it helps.
Marcello.
Hi Marcello,
thanks, but my problem is not finding the border. I already have it (with its own category) but assigning it the value from the surrounding (not null) value, e.g. max/min/etc.
The problem with kernel filters/moving windows is that they do not filter out null values…
giovanni
2012/6/19 Marcello Gorini <gorini@gmail.com>
Hey,
Hope it helps.
Marcello.
OK, sorry for that. So your problem is the famous edge effect that affects us all.
Well, I think you have a real problem there.
If you find a good solution, please share.
Best,
Marcello.
On Tue, Jun 19, 2012 at 11:39 AM, G. Allegri <giohappy@gmail.com> wrote:
Hi Marcello,
giovanni
Hey,
Hope it helps.
Marcello.
On 19/06/12 10:15, G. Allegri wrote:
I need to assign values to a the cells on the "border" of a raster. The
values assigned.
How about using an isnull() function on each cell, i.e.:
if(A==9999,max(if(isnull(A[1,1]),0,A[1,1]),if(isnull(A[1,0]),0,A[1,0]), etc, ),A)
Moritz
On Tue, Jun 19, 2012 at 12:39 PM, G. Allegri <giohappy@gmail.com> wrote:
Hi Marcello,
out null values...
AFAICT, r.neighbors ignores NULL values and assigns the new value from
the surrounding non-NULL values. You could then patch your original
map with the output of r.neighbors.
HTH,
Markus M
giovanni
assigned.
Hey,
# creates an inverted raster from your raster
> r.mapcalc "raster_inverted=if(isnull(raster,1,null())"
# grow this inverted raster by one cell
# now both rasters overlap at the border, so you can do whatever you want
> r.mapcalc "border=if(raster_inverted_grown==1 &&
> isnull(raster)==0,raster,null())"
Hope it helps.
Marcello.
grass-user mailing list
grass-user@lists.osgeo.org
Hi Moritz,
this is a partial solution (as assigning unlikely high/low values to the null cells), but it doesn’t solve, for example, the mode() function.
Anyway, this was the way I already followed
giovanni
2012/6/19 Moritz Lennert <mlennert@club.worldonline.be>
values assigned.
Moritz
I have considered r.neighbors but I need to apply the filter only to some specific categories (border cells in my case). A MASK wouldn’t solve my problem, because it would mask the neighbors…
giovanni
HTH,
Markus M
giovanni
assigned.
Hey,
Hope it helps.
Marcello.
specific categories (border cells in my case). A MASK wouldn't solve my
problem, because it would mask the neighbors...
You could replace 9999 (according to your first post the category of
border cells) with NULL, then run r.neighbors, without a MASK?
Markus M
giovanni
HTH,
Markus M
> giovanni
>>> The
>>> values
>>> assigned.
>> Hey,
>> the
>> want
>> Hope it helps.
>> Cheers,
>> Marcello.
Yes, with r.neighbors I woul chenge the values to NULL, but I don’t know how to solve the problem of applying the filter only to the cells with a specific value (involving only the values of their neighbors).
My border cells have assigned a 10000 value. I’m working on a DEM., so this fictious value is a way to code my borders. I want to apply the filter only on these cells, while leaving the others (not on the border) unaltered.
With r.mapcalc I use an if() statement, but with r.neighbors I would need a MASK.
giovanni
2012/6/19 Markus Metz <markus.metz.giswork@googlemail.com>
Markus M
giovanni
HTH,
Markus M
giovanni
The
values
assigned.
Hey,
the
want
Hope it helps.
Marcello.
On Tue, Jun 19, 2012 at 6:36 PM, G. Allegri <giohappy@gmail.com> wrote:
Yes, with r.neighbors I woul chenge the values to NULL, but I don't know how
r.neighbors followed by r.patch, no MASK? This will keep the valid
cells of the original map and only replace cells that are NULL in the
original map with values from the filtered map. E.g.
g.region -p rast=DEM
r.neighbors in=DEM out=DEM_filt method=mode
r.patch in=DEM,DEM_filt out=DEM_patched
My border cells have assigned a 10000 value. I'm working on a DEM., so this
MASK.
BTW, if the border problem arouse from reprojecting with a method
other than nearest, you can use in trunk as resampling method one of
bilinear_f,cubic_f,lanczos_f with r.proj to avoid the border effect.
Markus M
giovanni
> some
Markus M
> giovanni
>> HTH,
>> Markus M
>> > giovanni
>> >>> The
>> >>> null
>> >>> values
>> >>> assigned.
>> >> Hey,
>> >> in
>> >> the
>> >> want
>> >> Hope it helps.
>> >> Cheers,
>> >> Marcello.
>> > _______________________________________________
Right Markus
This is the simplest approach.
I didn’t know about these “fallbacks” methods in trunk. Very good.
I was thinking about that since a long time, because it’s a featue I find very useful in ArcGIS. GRASS gives a plus: the option to use fallbacks or not
It would be useful to have them in r.resamp.interp too. This is the command that “eats” my border.
giovanni
Markus M
giovanni
some
Markus M
giovanni
HTH,
Markus M
giovanni
The
null
values
assigned.
Hey,
in
the
want
Hope it helps.
Marcello.
FYI, Glynn has answered me right now on grass-dev saying that in trunk nmax, nmin, nmode, etc. are available, which discard NULL values.
giovanni
2012/6/20 G. Allegri <giohappy@gmail.com>
Right Markus
giovanni
Markus M
giovanni
some
Markus M
giovanni
HTH,
Markus M
giovanni
The
null
values
assigned.
Hey,
in
the
want
Hope it helps.
Marcello.
