[GRASS-user] Calculate statistics for raster values in polygons
Greetings
I have a vectorial data that divides my region in sub-areas. I want to calculate the average value of a raster but instead for all pixel values, I want to calculate the average of pixel values that are inside each polygonIs this possible in GRASS? If yes, how?
Thank you
Luis
Try to transform your vector areas into a raster map, afterwards you are able to use r.statistics (now, former polygons as the raster base map and desired raster as the cover map)…that should work!
Christian.
Sent: Wednesday, April 21, 2010 7:03 PM
To: GRASS user list
Subject: [GRASS-user] Calculate statistics for raster values in polygons
Greetings
Thank you
Luis
grass-user mailing list
grass-user@lists.osgeo.org
Luis Lisboa pisze:
Greetings
Thank you
Luis
v.rast.stats
On Wed, Apr 21, 2010 at 7:21 PM, Jarek Jasiewicz <jarekj@amu.edu.pl> wrote:
Luis Lisboa pisze:
Greetings
v.rast.stats
Or how about r.univar.zonal?
http://grass.osgeo.org/wiki/Addons#r.univar.zonal
Hi all
I’m reading the v.rast.stats Help and I’m a bit confused. It says “Calculates basic univariate statistics from a raster map only for the parts covered by the specified vector map”. But for instance if all my region is covered by different polygons and, if I want to calculate for each polygon my average value from raster, is this function helpful? (e.g. I have vector with zip codes for my region and I want to calculate average elevation of each zip code).
On Wed, Apr 21, 2010 at 6:21 PM, Jarek Jasiewicz <jarekj@amu.edu.pl> wrote:
Luis Lisboa pisze:
Greetings
Thank you
Luis
v.rast.stats
Luis Lisboa wrote:
Hi all
I'm reading the v.rast.stats Help and I'm a bit confused. It says "Calculates basic univariate statistics from a raster map only for the parts covered by the specified vector map". But for instance if all my region is covered by different polygons and, if I want to calculate for each polygon my average value from raster, is this function helpful? (e.g. I have vector with
yes, exactly the function you need. It adds nine attribute columns to your vector layer with min,max,mean, etc values calculated from the raster.
On Wed, Apr 21, 2010 at 6:21 PM, Jarek Jasiewicz <jarekj@amu.edu.pl <mailto:jarekj@amu.edu.pl>> wrote:
    Luis Lisboa pisze:
        Greetings
        If yes, how?
        Thank you
        Luis
        grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
    v.rast.stats
This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
