Hi Johannes
Yes, its in vector format, but it could be converted to raster if necessary.
I installed v.strahler with g.extension, but loading it produced an error. Is there another one?
Thanks
File “C:\OSGeo4W\apps\grass\grass-6.4.2\etc\wxpython\gui_m
odules\prompt.py”, line 1105, in OnKeyPressed
self.parent.RunCmd(cmd)
odules\goutput.py”, line 523, in RunCmd
task = menuform.GUI(show = None).ParseCommand(command)
odules\menuform.py”, line 1732, in ParseCommand
blackList = _blackList)
File “C:\OSGeo4W\apps\grass\grass-6.4.2\etc\python\grass\s
cript\task.py”, line 460, in parse_interface
tree = etree.fromstring(get_interface_description(name))
File
“C:\OSGeo4W\apps\Python27\lib\xml\etree\ElementTree.py”,
line 1283, in XML
return parser.close()
File
line 1636, in close
self._raiseerror(v)
File
line 1488, in _raiseerror
raise err
xml.etree.ElementTree
ParseError
no element found: line 1, column 0
On Mon, May 14, 2012 at 2:47 PM, Johannes Radinger <jradinger@gmx.at> wrote:
Hi Filipe,
you mean your hydrological network is in vector format?
Maybe you can try the v.strahler add-on but I don’t know
how uptodate this module is:
http://grass.osgeo.org/wiki/GRASS_AddOns#v.strahler
/johannes
Am 14.05.2012 um 13:26 schrieb Filipe Silva Dias:
Dear all,
I have a digitized hydrological network and I need to calculate the stream order (Horton, Strahler etc).
I found r.stream.order but it requires that the hydrological network comes from a DEM, which in my case produced an hydrological network that is considerably different than the digitized one (tried both with r.wateshed, r.terraflow and r.stream.extract).
Is there a tool capable of doing this? Apparently ArcGIS can do this, but id prefer na open source solution.
Thanks
Best regards
Filipe
grass-user mailing list
grass-user@lists.osgeo.org
