[GRASS-user] calculate the volume of a DEM with r.volume
Hello,
Indeed it worked when ‌I changed the name!
Thank you very much!
Marion
On 07/13/2018 10:51 AM, marion-brunet@sfr.fr wrote:
‌Hello,
I am working on Windows and I tried using GRASS 7.2.2, GRASS 7.4.0 and GRASS 7.4.1 to see if there is any difference, but it is always the same.
I have a ratser map called dec-juin
First I did r.clump input=dec-juin@1217_Interpo0618 output=test
to get the clumps
Then I did r.volume input=dec-juin@1217_Interpo0618 clump=test@1217_Interpo0618
to have the volume.
The result I have is:
(Fri Jul 13 14:12:45 2018)
Volume report on data from <dec-juin@1217_Interpo0618> using clumps on <test@1217_Interpo0618> raster map
Category Average Data # Cells Centroid Total
Number in clump Total in clump Easting Northing Volume
1 -8.02 -72 9 191262.28 1222178.97 -22.59
2 -9.02 -622 69 191265.64 1222177.29 -194.78
3 -8.04 -394 49 191268.44 1222176.73 -123.30
4 -7.08 -276 39 191271.23 1222177.85 -86.46
5 -5.94 -427 72 191274.59 1222176.73 -133.75
6 -4.30 -275 64 191285.22 1222178.97 -86.09
7 -5.10 -2714 532 191288.58 1222174.50 -849.47
8 -0.60 -7 12 191221.43 1222177.29 -2.27
9 -8.95 -1030 115 191230.39 1222176.17 -322.31
10 -10.06 -1217 121 191245.49 1222175.61 -380.88
11 -10.93 -1956 179 191249.97 1222177.29 -612.34
12 -10.24 -645 63 191259.48 1222175.61 -201.92
13 -7.05 -621 88 191329.43 1222177.29 -194.28
14 -7.51 -60 8 191336.14 1222177.29 -18.81
15 -7.47 -30 4 191337.26 1222177.29 -9.35
16 -8.04 -322 40 191340.06 1222177.29 -100.63
17 -8.99 -108 12 191343.98 1222177.29 -33.78
18 4.98 45 9 191182.26 1222175.05 14.03
etc
etc
24458 -5.50 -22 4 191397.13 1221585.50 -6.88
24459 -5.51 -33 6 191378.11 1221584.39 -10.34
24460 -5.52 -11 2 191380.91 1221584.39 -3.45
24461 -5.27 -30348 5764 191309.84 1221601.17 -9498.51
24462 -5.49 -38 7 191358.53 1221582.15 -12.02
24463 -5.49 -22 4 191363.56 1221583.83 -6.87
24464 -5.48 -11 2 191385.38 1221583.83 -3.43
24465 -5.49 -11 2 191387.06 1221583.83 -3.44
24466 -5.50 -11 2 191388.74 1221583.83 -3.44
24467 -5.50 -22 4 191360.20 1221582.71
-6.88
24468 -5.92 -523187 88358 191241.58 1221675.00 -163750.63
(Fri Jul 13 14:13:03 2018) La commande s’est terminée (18 sec)
As you can see, I have nothing at the end of the command… But I know it is finished, because when I created the clumps it said that it created 24468 clumps.
Do you need any more information?
Thank you very much
De : “Markus Neteler”
A : marion-brunet@sfr.fr,“grass-user”
Envoyé: jeudi 12 juillet 2018 16:43
Objet : Re: [GRASS-user] calculate the volume of a DEM with r.volume
Hello Marion,
On Wed, Jul 11, 2018 at 10:32 AM, <marion-brunet@sfr.fr> wrote:
Hello,
I tried using r.volume as you suggested. According to the documentation it
is suitable for what I am trying to do.
However, when I use it, I don’t have the “Total volume” line at the end of
the report, like it is shown in the documentation. I just have the total
volume of each clump, but not of all the clumps… Has it ever happened to
you when using this command?
That’s weird! Which version/operating system do you use?
in the command line
I simply wroter.volume input=difference clump=clump in the command line
Here on command line:
GRASS 7.4.1svn (nc_spm_08_grass7):~ > g.region raster=elevation
GRASS 7.4.1svn (nc_spm_08_grass7):~ > r.volume input=elevation clump=geology_30m
100%
Volume report on data from using clumps on <geology_30m> raster map
217 118.93 86288828 725562 635325.00 221535.00 8628882798.63
262 108.97 21650560 198684 638935.00 222495.00 2165056037.02
270 92.23 63578874 689373 642405.00 221485.00 6357887443.53
405 132.96 33732662 253710 631835.00 224095.00 3373266208.59
583 139.35 3011288 21609 630205.00 224665.00 301128821.55
720 124.30 599618 4824 634075.00 227995.00 59961816.06
766 132.43 936791 7074 631425.00 227845.00 93679120.08
862 118.31 7302317 61722 630505.00 218885.00 730231746.74
910 94.20 4235816 44964 639215.00 216365.00 423581613.11
921 135.22 1693985 12528 630755.00 215445.00 169398523.05
945 127.24 1145 9 630015.00 215015.00 114512.03
946 89.91 365748 4068 639085.00 215255.00 36574833.85
948 129.02 112632 873 630185.00 215115.00 11263181.57
Total Volume = 22351026655.81
… which looks ok.
Can you say a bit more about your system?
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
