[GRASS-user] Calculating eigen values and % variance explainedafter PCA analysis
I will download and compile 6.4 from source and give the addon a go. Will get back to on the outcome.
Installed Fort77 and f2c as per your suggestion.
Many thanks,
Wesley
Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de> 02/25/09 3:31 PM >>>
Wesley:
I see that I would need to upgrade to 6.4 using svn. I currently
install using synaptic, does this mean I need to compile from source
and then add the m.eigensystem addon?
Not sure about f77, is this a fortran compiler? I have gfortran
compiler version 4.2.3, will this do?
(@Hamish: apologies for the interference :-p)
Wesley,
perhaps it's better to upgrade to 6.4 (or why not to grass6_devel =
grass65 ?). grass needs to be compiled first (don't install), then
compile m.eigensystem and install in the end grass.
I don't know if gfortran will help you. But you can install fort77 and
f2c under ubuntu:
# from "apt-cache search fort77"
f2c - A FORTRAN 77 to C/C++ translator
fort77 - Invoke f2c like a real compiler
If you have success running m.eigensystem, can I please ask you to let
the list (and me :-p) know about it? I compiled m.eigensystem without
errors but it doesn't seem to work within from grass65. I am currently
re-compiling grass6_devel to see whether it will work or not.
Or do I need to work with grass6.4?
Kind regards, Nikos
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
Nikos:
# Answering to myself :-p
Yes, it works. I was confused by the fact that nomatter what argument is
given to m.eigensystem it does not print short description/help
messages. Instead it runs. Of course "man m.eigensystem" lets you read
the manual.
So here is an(other) example:
        # get covariance matrix
        r.covar
        map=MOD2006_239_500_sur_refl_b02,MOD2006_239_500_sur_refl_b06,MOD2006_239_500_sur_refl_b07,MOD2007_242_500_sur_refl_b02,MOD2007_242_500_sur_refl_b06,MOD2007_242_500_sur_refl_b07
        r.covar: complete ...
         100%
        230737.894890 195532.919270 135003.507092 160548.524865
        157011.283237 109163.152597
        195532.919270 370156.630631 302611.016829 169840.571354
        329762.496795 255222.040018
        135003.507092 302611.016829 269579.148609 123245.319257
        267537.923455 218257.721900
        160548.524865 169840.571354 123245.319257 283021.657148
        227212.808304 97810.797191
        157011.283237 329762.496795 267537.923455 227212.808304
        411853.700150 306427.271345
        109163.152597 255222.040018 218257.721900 97810.797191
        306427.271345 287565.577718
        # output in a file
        r.covar
        map=MOD2006_239_500_sur_refl_b02,MOD2006_239_500_sur_refl_b06,MOD2006_239_500_sur_refl_b07,MOD2007_242_500_sur_refl_b02,MOD2007_242_500_sur_refl_b06,MOD2007_242_500_sur_refl_b07 > test_m.eigensystem
        # edit the file and add a number K which corresponds to the
        number of rows and columns of the cov matrix
        # in my example: add the number "6" in the top line of the
        test_m.eigensystem file
        # run m.eigensystem
        m.eigensystem < test_m.eigensystem
        E 1384795.0108207434 .0000000000 74.74
        V .4835516921 .0000000000
        V .8488469532 .0000000000
        V .6938880512 .0000000000
        V .5233792650 .0000000000
        V .8927982533 .0000000000
        V .6795723454 .0000000000
        N .2806476574 .0000000000
        N .4926606871 .0000000000
        N .4027243813 .0000000000
        N .3037631075 .0000000000
        N .5181694995 .0000000000
        N .3944157157 .0000000000
        W 330.2586235389 .0000000000
        W 579.7498611168 .0000000000
        W 473.9152326520 .0000000000
        W 357.4602642457 .0000000000
        W 609.7679463257 .0000000000
        W 464.1378182325 .0000000000
        E 241514.2792070895 .0000000000 13.03
