I'm using processed SRTM data from http://srtm.csi.cgiar.org/ the
current release is Version 3, which was a great improvement from V1
and 2 especially with 1/2 pixel shift, coastline boundary clipping and
filled holes.
I would like to ask others on using this dataset in calculating slope.
I now have a working GRASS database with SRTM imported (as integer).
In running r.slope.aspect, do I need to do further pre-processing of
the SRTM DEM? The 90m pixel size is OK for the purpose of the
research.
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
Hi Maning,
did you use r.in.gdal, right?
the SRTM DEM?
no, you don’t.
Marco
Da: grass-user-bounces@lists.osgeo.org per conto di maning sambale
Inviato: ven 09/05/2008 10.24
A: grass-user
Oggetto: [GRASS-user] calculating slope in SRTM data fromhttp://srtm.csi.cgiar.org/
I’m using processed SRTM data from http://srtm.csi.cgiar.org/ the
filled holes.
research.
cheers,
maning
| _.-. |“Ohhh. Great warrior. Wars not make one great.” -Yoda |
| ‘-._"7’ |“Freedom is still the most radical idea of all” -N.Branden|
| )/LI
grass-user mailing list
grass-user@lists.osgeo.org
Marco,
Yes
the SRTM DEM?
no, you don't.
Alright, thanks!
cheers,
maning
| _)_/LI
On Fri, 2008-05-09 at 11:37 +0200, marco.pasetti@alice.it wrote:
Hi Maning,
the SRTM DEM?
no, you don't.
Marco
I also use this product. I didn't do anything but importing. Only, when
interpolating the DEM at a different resolution I follow someone's
advice and use bilinear interpolation.
Greets,
Nikos
