I have 25000 maps, generated by simulation predictions, and I would
like to calculate some descriptive stats, like mean, standard
deviation, median, quartiles.
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
Just one clarification: I would like to calculate these descriptive
stats for each cell, to obtain "variability maps".
Rainer
On Mon, Feb 9, 2009 at 5:57 PM, Rainer M Krug <r.m.krug@gmail.com> wrote:
Hi
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Rainer
> Hi
> Is there an easy way of doing this in GRASS?
> Thanks,
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Faculty of Science
> Private Bag X1
> Matieland 7602
> South Africa
University of Wuerzburg
Institute of Geography
Department of Remote Sensing
Remote Sensing and Biodiversity Unit
Am Hubland
97074 Wuerzburg, Germany
German Aerospace Center (DLR)
German Remote Sensing Data Center (DFD)
Rainer
> Hi
> Thanks,
> Rainer
> Faculty of Science
> Private Bag X1
> Matieland 7602
> South Africa
Am Hubland
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Rainer
Hi
r.series ?
You will probably have to use xargs to collate that many map names...
stats for each cell, to obtain “variability maps”.
Rainer
Hi
r.series ?
You will probably have to use xargs to collate that many map names…
Or you can use g.mlist if the names have a common prefix, suffix, etc. This assumes you want a single map that displays the result of all the input maps.
E.g.
r.series input=“g.mlist rast pattern='prefix_*' sep=,” output=prefix_stddev method=stddev
Rainer
On Mon, Feb 9, 2009 at 5:57 PM, Rainer M Krug <r.m.krug@gmail.com <mailto:r.m.krug@gmail.com>> wrote:
Hi
r.series ?
E.g.
r.series input="`g.mlist rast pattern='prefix_*' sep=,`" output=prefix_stddev method=stddev
Yes, but if I'm not mistaken, this won't work with 25000 maps as it would create a too long command line. But please correct me if I'm wrong.
>>> Rainer
>>>> Hi
>> r.series ?
> input maps.
> E.g.
25000 maps will probably also exceed the resource limit for the number of
open descriptors. It's common for user processes to be limited to 1024
descriptors; you need to modify /etc/security/limits.conf to increase the
limit.
On Tue, Feb 10, 2009 at 12:06 PM, Glynn Clements
>>> Rainer
>>>> Hi
>> r.series ?
> input maps.
> E.g.
limit.
I asked the same question on the R mailing list, and got the following
promising response:
This is how can you can do it with the raster package
# create a list (or vector) of file names, e.g. :
fn <- list()
for (i in 1:n) { fn[i] <- paste('myfile', i, '.tif', sep='') }
# make a RasterStack
s <- stack(fn)
r1 <- mCalc(s, fun=mean)
r2 <- mCalc(s, fun=sd)
r can be plotted, coerced to sp objects, etc.
plot(r1)
# or saved to file
r1 <- setFilename(r1, 'cellmeans.tif')
r1 <- writeRaster(r1, format='GTiff')
I am trying it at the moment with 1002 maps and, apart from the fact
that it takes some time (which I am sure it would in GRASS as well),
it seems to be working.
I will be looking at R.series again later, when I run the simulations
again. But I assume that there will be serious problems with 25000
maps - I might have to do it with a sample of maps.
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
for the standard stats available from r.univar
n
minimum
maximum
range
mean
mean of absolute values
standard deviation
variance
variation coefficient
sum
(ie not median, quartiles) you can use r.series in a loop, eg 1000 maps
at a time, and then sum up the resulting 25 summary maps before doing a
little math to get the overall answers. (or lots of 100 maps x250, ...)
I think you would need to add a new sum_of_squares method to r.series
to calculate variance/stdev. see r.univar/stats.c print_stats()
n
minimum
maximum
range
mean
standard deviation
variance
sum
Thanks a lot Hamish - I will look into that and see what can do. In
the meantime, it works in R, as described above.
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
