Hallo,
I've got a point file and populated (v.what.rast) it with values from a flow direction raster (flow direction from r.watershed).
I want to use these values to rotate the symbol in ps.map but therefore I've to recalulcate the values in the direction-column of the point file (x*45+90 or so).
How can that be done? I thought about v.reclass but don't really know how?!
Another option would be to access the sqlite database and perform the calculation there (I am working in a python script) like:
database = sqlite3.connect(os.path.join(gisdbase, location, mapset, 'sqlite.db'))
db = database.cursor()
db.execute .... but what is the correct command for calculation within a database??
Probably it is easier than I think...
/j
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
On 16/05/11 16:32, Johannes Radinger wrote:
Hallo,
If you want to modify an existing column:
v.db.update col=YourExistingColumn value=YourCalculation
If you want to create a new column:
v.db.addcolumn col="YourNewCol double precision"
v.db.update col=YourNewCol value=YourCalculation
Moritz
Am 17.05.2011 um 16:14 schrieb Moritz Lennert:
Hallo,
Thank you that was what I was looking for...
/j
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
