Dear R-gurus,
(native wingrass)
I have a script under c:/grass/scripts and I start it invoking
GRASS MSYS Console and calling the script. But
when I do that I can´t see which command are
running. Is there a way of I see the command that
are running?
Best wishes,
miltinho
brazil
On 13/11/08 17:50, Milton Cezar Ribeiro wrote:
Dear R-gurus,
(native wingrass)
I have a script under c:/grass/scripts and I start it invoking GRASS MSYS Console and calling the script. But
when I do that I can´t see which command are running. Is there a way of I see the command that
are running?
Which script language are we speaking about here: bash, R, other ?
Moritz
Hi Moritz,
It is a good question. As I am running Native Wingrass from GRASS MSYS, I believe the it is “bash”.
miltinho
2008/11/13 Moritz Lennert <mlennert@club.worldonline.be>
Dear R-gurus,
(native wingrass)
are running?
Moritz
You could add some echo lines before each important comand so the
script will print whatever is doing. Something like this:
echo "Erasing all. Goodbye cruel world"
g.mremove rast=*
IMPORTANT: DO NOT EXCECUTE ABOVE LINE (left -f switch off on purpose)
On Thu, Nov 13, 2008 at 3:49 PM, Milton Cezar Ribeiro
<miltinho.astronauta@gmail.com> wrote:
Hi Moritz,
believe the it is "bash".
miltinho
Dear R-gurus,
(native wingrass)
are running?
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
are running?
If you add the command "set -x" to the top of the script, bash will
print each command as it executes it.
