[GRASS-user] Call Grass modules from C++ code
I'm implementing a model in C++ and I need to call some Grass modules from my code.
Which is the best way to do it? Are there APIs that allow me to use the modules as a library?
Thanks!
Matteo
see programmers manual[1]
http://grass.osgeo.org/programming7/
On Fri, Feb 15, 2013 at 7:54 PM, matteo poletti <pollo1_91@yahoo.it> wrote:
I’m implementing a model in C++ and I need to call some Grass modules from my code.
Thanks!
Matteo
grass-user mailing list
grass-user@lists.osgeo.org
Rashad
On Fri, Feb 15, 2013 at 5:22 PM, Rashad M <mohammedrashadkm@gmail.com> wrote:
my code.
See also here (the page should be expanded):
http://grasswiki.osgeo.org/wiki/GRASS_and_C++
Da: Rashad M <mohammedrashadkm@gmail.com>
Thanks
for your answer. I've seen the programmer's manual, but it seems to me
that it presents operations at a lower level than the one that I need.
For example if I want to call the module v.in.ogr from my code, what should I do? Maybe I'm missing something...
Thank you for your help!
Matteo
Da: Markus Neteler <neteler@osgeo.org>
Ok, I have understood that I need to put the keyword "extern". But I'm still confused about how to call other Grass module.
I've tried to see the examples linked in the wiki but it's a little bit difficult to understand how they work. Can you please suggest me a file where there is an example of calling another module?
Matteo
Grass module.
have a look at the functions in lib/gis/spawn.c.
there is also the less portable G_system() to look at in grass6.
you might look at raster/r.topmodel/misc.c in trunk for an example.
Hamish
Da: Hamish <hamish_b@yahoo.com>
Ok, so if I got it right I need to do a sys call exec. What do you usually do for reading the module's output?
I suppose that, doing the things this way, I'll need to run my program inside a grass shell to have it working.
Do I need the "extern" keyword in this case? I guess not since I'm doing a sys call.
Maybe I've misunderstood the example...
Thanks!
Matteo
I hope this will help:
http://stackoverflow.com/questions/478898/how-to-execute-a-command-and-get-output-of-command-within-c
If you are using some framework such as Qt, you can use the way used
in this framework.
Yes, you always need to run your program (which uses lib or modules)
in grass session. Your program is in fact a grass module. However,
there is an alternative -- to set up some environment variables (most
recently discussed in thread "Bash aliases in GRASS").
http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
Exactly, "extern" is necessary to properly include function declarations.
Best,
Vaclav
BTW, I would ask this question on grass-dev. For me, it is more
developer than user question because of C++.
Thanks!
Matteo
