I'm new to GRASS.
I use ubuntu, and use the command:
sudo apt-get install grass
to install GRASS 6.0.2.
However, I feel it is good until I found that I can not run v.report, and some other modules. I know that these modules are exist in GRASS.
So, should I compile from the source code, or, install some other packages ?
卜坤 wrote:
I'm new to GRASS.
packages ?
v.report is not present in 6.0. Here's 6.0's manual [1] where you can
check what modules are available. The latest stable version is 6.2.1,
but I'm affraid v.report in broken in 6.2.1. Bugfix 6.2.2 release,
including the fix for v.report and more, is planned.
If you need only v.report, please download it from the cvs online
interface, put it into your PATH and it should work. It's only a shell
script, so need to compile etc.
[1]http://grass.itc.it/grass60/manuals/html60_user/vector.html
[2]http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/v.report/v.report
Maciek
hi,
you can get fresh packages from http://les-ejk.cz/ubuntu
jachym
卜坤 píše v Pá 08. 06. 2007 v 23:13 +0800:
I'm new to GRASS.
grassuser mailing list
grassuser@grass.itc.it
Jachym Cepicky
e-mail: jachym.cepicky@gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
