I have installed grass 7 on ubuntu 14.04, 64 bit, from the source code.
The grass70 opens without any problems, but I'm unable to find the
command '*g.mlist*'. However, "g.list" opens without any errors.
Also, I'm unable to install any of the Add-ons.
I think I have missed to configure some files.
I will be grateful if any of you can help in resolving this issue.
The grass70 opens without any problems, but I’m unable to find the
command ‘g.mlist’. However, “g.list” opens without any errors.
Also, I’m unable to install any of the Add-ons.
On Wed, Dec 10, 2014 at 9:02 AM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
On 10.12.2014 09:45, Rajat Nayak wrote:
Hello,
g.mlist does not exist anymore. `g.list`, however, features all of its
functionalities.
Thank you for your mail Nikos.
Sorry, I did not realise pattern option is there in 'g.list' now.
Add-ons, I tried installing using g.extensions. Also tried
using Settings->Addons extensions->install extension from addons.
Dear Rajat,
What is the error message saying (for failing to install an add-on)?
I did a quick test installing add-ons from the GUI. It works just fine for me (tested both GRASS ver. 6.4.3 inside OSGeoLive ver. 7.9 & latest GRASS ver. 7.0.0svn from my Funtoo box). I am sorry that I can't be of any help for this one. Maybe someone working with Ubuntu can help further?
Sorry, I did not realise pattern option is there in ‘g.list’ now.
Dear Rajat,
I did a quick test installing add-ons from the GUI. It works just fine for me (tested both GRASS ver. 6.4.3 inside OSGeoLive ver. 7.9 & latest GRASS ver. 7.0.0svn from my Funtoo box). I am sorry that I can’t be of any help for this one. Maybe someone working with Ubuntu can help further?
...compiling from the source code in Ubuntu can create problems if not
configured properly. I will try to work on it in free time.
Sorry, which version do you compile? I don't run Ubuntu myself (anymore, since quite some time). But I used to do this very (very) often. Which instructions do you follow?
