[GRASS-user] Can someone help me troubleshoot GRASS on Windows 10
Hi GRASS users,
Longtime GIS'er but newbie to GRASS. I've never been able to get it to work properly on my workstation and have always fallen back on Esri or, QGIS built-in functions. Now I am in a situation where I have to get GRASS to work because it seems like the fastest way to do some hydro things. I am trying to use it inside of QGIS 3.12.
Here is my problem. I have a UTM-projected DEM as input, I just want to run r.flow and it fails, reporting:
"The following layers were not correctly generated. C:/Users/username/AppData/Local/Temp/1/processing_ipancU/89aab5fc64c6999046d99c2e0028b/flowaccumulation.tif C:/Users/username/AppData/Local/Temp/1/processing_ipancU/bded4092193446b883446b88344c55272310fa8/flowlength.tif C:/Users/username/AppData/Local/Temp/1/processing_ipancU/f4a65331b4ef4fa5a6b2ba826efdd9b4/flowline.gpkg
You can check the 'Log Messages Panel' in QGIS main window to find more information about the execution of the algorithm."
However, when I check the log messages panel, here is what I see:
Grass7 tab: only INFO level messages showing the original command payload
all the other tabs: nothing
So, not much given to troubleshoot. This behavior happens with *every* GRASS tool I try to run, including even v.buffer. So something is definitely not right.
*About my setup*
I do not have admin access rights to my workstation as this is a production box in a big enterprise. However I do have access to write to C:/ directories outside of the typical locked down stuff (Program Files, Program Files (x86), etc). I have QGIS currently installed to C:\QGIS_3 and GRASS sits under that. The workstation is not connected to the internet in case that matters.
Thanks for any insight,
eric
Eric Eagle wrote
Hi GRASS users,
*About my setup*
some more details are needed:
* which GRASS GIS version used
* g.proj -p output
* g.region -p output
* exact command failing
I guess it has nothing to do with windows 10. works here on several windows
10 boxes.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
Thank you Helmut - can you tell me how I run those commands at command line in OSGEO shell?
Also the folder says Grass78
eric
Sent: Tue Sep 29 23:21:45 CEST 2020
To: <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] Can someone help me troubleshoot GRASS on Windows 10
Eric Eagle wrote
> Hi GRASS users,
> *About my setup*
* g.proj -p output
10 boxes.
best regards
Helmut
grass-user mailing list
do: gdalinfo your-UTM-projected-DEM
GRASS GIS is bundled with QGIS 3.12. start GRASS GIS itself.
- create location based upon your-UTM-projected-DEM
- g.proj -p
- r.external input=your-UTM-projected-DEM output=linked_dem
- g.region -p -a raster=linked_dem align=linked_dem
best regards
Helmut
