Hi, the attached 3D image I believe was generated by software. I was wondering is someone could tell me if there is a way to create something similar with GRASS, out of shapefiles (or do I need something more, like an aerial photo?)
Many thanks
Bill
Many thanks
Bill
aerial photo?) Many thanks
Bill
Looks like some kind of thematic map, draped over an elevation surface, with a
vector representation of a river system on the right-side.
This is not at all difficult to do in GRASS, you just need some data first. Do
you have
1. thematic data in raster / vector format?
2. data sufficient to generate an elevation surface, or a DEM?
3. hydrologic data in raster / vector format?
Once you have these things, all in the same coordinate system- planar if
possible, bring them into a grass mapset (see the manual). You can generate
perspectives like the attached image with a tool called 'nviz'. Here is an
example, using a DEM, aerial photo, and 3D tree objects (see the GRASS
add-ons page):
