I just tried to create a new location for UTM Zone 10 using the wxPython
GUI. I could assign a name to the new location, specify defining it from a
list, and selecting 'utm' from that dialog box. However, on the next dialog
box where the zone is to be entered I cannot change the default '30' to
anything but '0'. Is this like the origins with 'll'?
defining it from a
the next dialog
default '30' to
Michael & myself have been trying to fix it off-list, but to
be honest we are mostly stumped. (it works for him on Mac)
use the text-based location wizard (g.setproj), after starting
grass with "grass64 -text" or "grass64 -tcltk" from the command
line. your gui choice is sticky so reset it to wx with g.gui
later.
Michael & myself have been trying to fix it off-list, but to be honest we
Ah!
use the text-based location wizard (g.setproj), after starting grass with
"grass64 -text" or "grass64 -tcltk" from the command line. your gui choice
is sticky so reset it to wx with g.gui later.
I just used a text editor on PROJ_INFO after accepting the default '30'.
Isn't it a wxPython spin-control widget? I've several of those in my
python approximate reasoning models.
In that case you should double check that if(?) the PROJ_INFO
file has a +lon_0 set, it is set appropriately and not still
using the central longitude from Zone 30...
yes
I've several of those in my python approximate reasoning
models.
I'm about to suggest that we scrap the spin box and return
to a simple text box (rather than the long pull-down) and
have it validate only values 1-60.
A spin box is the right tool for the job, so I'd like to keep
banging our heads against this one until we understand the
deeper cause (in the dev branch, not the release branch of
course).
Also: the DEFAULT_WIND and WIND files contain a zone field.
In that case you should double check that if(?) the PROJ_INFO file has a
+lon_0 set, it is set appropriately and not still using the central
Hamish,
It doesn't:
name: Universal Transverse Mercator
proj: utm
datum: nad83
ellps: grs80
zone: 10
no_defs: defined
nadgrids: WO
