[GRASS-user] Cannot display raster maps
   Running 7.7.svm r73534.
   When I try to display a raster DEM map in the monitor this message and
traceback displays:
Rendering failed: Overlays multiple PPM image files.
Usage:
g.pnmcomp input=name[,name,...] [mask=name[,name,...]]
[opacity=value[,value,...]] output=name [output_mask=name] width=value
height=value [bgcolor=name] [--overwrite] [--help] [--verbose]
[--quiet] [--ui]
Flags:
Parameters:
input Name of input file(s)
mask Name of input mask file(s)
opacity Layer opacities
output Name for output file
output_mask Name for output mask file
width Image width
height Image height
bgcolor Background color
ERROR: g.pnmcomp: Sorry, <-> is not a valid flag
ERROR: g.pnmcomp: Sorry, <o> is not a valid flag
Reason:
   File "/usr/local/grass-7.7.svn/gui/wxpython/mapwin/buffered.py", line 924, in _updateM
     windres=self._properties.resolution)
   File "/usr/local/grass-7.7.svn/gui/wxpython/mapdisp/main.py", line 298, in Render
     return Map.Render(self, *args, **kwargs)
   File "/usr/local/grass-7.7.svn/gui/wxpython/core/render.py", line 1249, in Render
     self.renderMgr.Render(force, windres)
   File "/usr/local/grass-7.7.svn/gui/wxpython/core/render.py", line 603, in Render
     if self._renderLayers(env, force) == 0:
   File "/usr/local/grass-7.7.svn/gui/wxpython/core/render.py", line 542, in _renderLayers
     layer.GetRenderMgr().updateProgress.emit(layer=layer)
   File "/usr/local/grass-7.7.svn/etc/python/grass/pydispatch/signal.py", line 229, in emit
     dispatcher.send(signal=self, *args, **kwargs)
   File "/usr/local/grass-7.7.svn/etc/python/grass/pydispatch/dispatcher.py", line 349, in send
     **named
   File "/usr/local/grass-7.7.svn/etc/python/grass/pydispatch/robustapply.py", line 60, in robustApply
     return receiver(*arguments, **named)
There may be more but it cannot be displayed as the error window won't
scroll vertically.
   I've not before seen this error and have no idea how to respond. Your help
is needed.
Rich
   Upgrading to r73552 doesn't resolve the error.
Rich
traceback displays:
   Any dev have an idea what broke? I cannot use grass on my projects until
this is fixed as the monitor (regardless of how started) will not display
raster or vector maps.
   If I correctly recall, this started with release 73539.
Help needed,
Rich
On Tue, Oct 16, 2018 at 5:53 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
> traceback displays:
Did you recompile GRASS GIS with after a full
make distclean
If not, that may help.
On Tue, 16 Oct 2018, Markus Neteler wrote:
Did you recompile GRASS GIS with after a full make distclean ?
Markus,
   Always. I run, in sequence, configure; make; make install; make distclean.
   Are there tests that can help define the source of the problem? When I
looked at the g.pnmcomp manual page I read that it's oriented for developers
not end users.
Rich
On Tue, Oct 16, 2018 at 6:10 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus,
The correct order would be:
make distclean; svn update; configure; make; make install
Note the distclean in the _beginning_ to compile from a clean source tree.
Just to be sure better have it first.
not end users.
Probably (cannot say right now) the latest parser change is causing troubles.
Currently being investigated...
Markus,
   That's what I wrote. After running svn up I run configure; make; make
install; make distclean. This leaves the source tree clean prior to the next
svn up.
   Whether I run make distclean after installing the latest release, or just
before the next svn up should not matter. The directory ~/gis/grass/grass7_trunk/
is in the same state. I've been doing this for quite a few years and only
yesterday did this display error show up.
troubles. Currently being investigated...
   Let me know if I can test changes on my installation.
Best regards,
Rich
On Tue, Oct 16, 2018 at 9:19 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
No worries, it was just meant as a recommendation.
A fix was applied to trunk a few minutes ago.
I recompiled trunk and display works fine (also the flags).
A fix was applied to trunk a few minutes ago. I recompiled trunk and
Markus,
   Woo-ha! That did the trick.
   Many thanks to you and all who keep GRASS at the top of the OS GIS ladder.
Very much appreciated.
Best regards,
Rich
