[GRASS-user] Cannot import (v.in.ogr) shapefiles anymore
I had recently a clean install of grass (6.2.3 from ubuntu
repositories) and grass 6.3.cvs (configured with
"--with-sqlite=yes", compiled and installed).
Yet, whenever I try to import a shapefile (created for
instance with OpenEV) I get an error "cannot open database
... .... / cannot open database ... ... by driver sqlite).
I have checked that sqlite is installed...
Any ideas?
Thank you,
Nikos
Any ideas?
What does db.connect -p tell you ?
Can you connect to the database with sqlite ?
Moritz
"> db.connect -p" gives:
driver:sqlite
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema:(null)
group:(null)
( and in the gui of v.in.ogr, among other I get:
"DBMI-SQLite driver
error:
Cannot open database: unable to open database file" )
On Tue, 8 Jan 2008 12:55:48 +0100 (CET)
ubuntu
database
sqlite).
> Any ideas?
Moritz
         Nikos Alexandris - Ph.D. Candidate
            Department of Remote Sensing
                       and
            Landscape Information Systems
                     (FeLIS)
      Faculty of Forestry and Natural Environment
          Albert-Ludwigs-University Freiburg
            Tel. +49 (0) 761 203 3697
            Fax. +49 (0) 761 203 3701
             Skype: Nikos.Alexandris
           Address: Tennenbacher str. 4
              D-79106 Freiburg i. Br.
                     Germany
The strange thing here is that you have the database driver set do
sqlite but the database set to dbf... Either change the driver to dbf
or the database to a sqlite file.
The db.connect man page has some nice exemples
http://grass.ibiblio.org/grass61/manuals/html61_user/db.connect.html
Daniel
driver:sqlite
schema:(null)
group:(null)
"DBMI-SQLite driver
error:
> ubuntu
> database
> sqlite).
> > Any ideas?
> Moritz
                       and
                     (FeLIS)
                     Germany
grass-user mailing list
grass-user@lists.osgeo.org
Just to complete: for the sqlite driver, the database is a file, not a
directory as for the dbf driver.
Moritz
Thank you a lot!
I never experienced the same problem in the past... So I
must have messed up something while re-installing
grass(6.2.3 and 6.3.svn... now).
On Tue, 8 Jan 2008 14:01:37 +0100 (CET)
driver set do
driver to dbf
a file, not a
Moritz
                       and
                     (FeLIS)
                     Germany
I followed the man page... and it works!
(db.connect driver=sqlite
database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db')
On Tue, 08 Jan 2008 14:08:41 +0100
Thank you a lot!
> driver set do
the
> driver to dbf
is
> a file, not a
> Moritz
