When I try to save my map display as any kind of image (tiff, bmp, jpeg), it displays an error “couldn’t execute gdal_translate: no such file or directory” and saves it as a ppm image. I do have gdal_translate, it is located in /usr/local/grasslib/bin/.
- Is this not the usual place for gdal_translate?
- If it is, why can Grass not find it? Is there some sort of environment variable that needs to be set?
Romy
Romy Schneider
Visualization Specialist
Texas Advanced Computing Center
The University of Texas at Austin
[http://www.tacc.utexas.edu](http://www.tacc.utexas.edu)
What happens when you type gdal_translate from the GRASS command prompt?
If you get the same error, you may need to make sure that /usr/local/grasslib/bin/ is in your PATH variable.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 12 Sep 2006 12:50:43 -0500
To: grassuser@grass.itc.it
Subject: [GRASS-user] Cannot save map display as anything but ppm image
Romy
Romy Schneider
Yeah, it says command not found. I added the path to my PATH variable, and that fixed it. Thanks.
Michael
phone: 480-965-6213
fax: 480-965-7671
To: <grassuser@grass.itc.it>
Romy
Romy Schneider
