[GRASS-user] Can't edit GRASS in QGis anymore
Date: Tue, 1 Nov 2011 16:38:16 -0700
Subject: [GRASS-user] Can't edit GRASS in QGis anymore
To: GRASS user list <grass-user@lists.osgeo.org>
Message-ID:
  <CAOL+ROGBJeD5AaJk=mwE=qpEOYkCiDCWNm9Rbm1_V8rsPb9+fA@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
I realize this might be more of a QGis question than a GRASS one, but
perhaps the same problem has affected someone here. In QGis when I click
on the "Edit GRASS Vector Layer" button, I no longer can see the GRASS
layer and do any editing operations to it. The Symbology pane of the
"GRASS Edit" window shows all of the data types as being un-checked, and I
cannot turn them back on. What makes this doubly frustrating is that at
one point this worked fine, I fiddled with the settings in the Symbology
window, and afterwards I had the problem I'm describing now.
I've tried removing and reinstalling QGis and GRASS and I cannot seem to
affect this behavior.
Any clues greatly appreciated.
Reinstalling does not help, removing your preferences (under ~/.qgis) should do.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Deleted it, but I still can’t edit GRASS layers via QGis. I can toggle edit mode, but the layer disappears from the QGis display and all of the GRASS data types are unchecked in the Symbology tab of the GRASS Edit window. Could it be some sort of mapset owner mismatch? I think I’d get an error when I click on the “Edit” button. At least that’s what happens when I fire up QGis from the command line as another user.
Roger
On Tue, Nov 1, 2011 at 11:52 PM, Paolo Cavallini <cavallini@faunalia.it> wrote:
Subject: [GRASS-user] Can’t edit GRASS in QGis anymore
Message-ID:
Content-Type: text/plain; charset=“utf-8”
on the “Edit GRASS Vector Layer” button, I no longer can see the GRASS
“GRASS Edit” window shows all of the data types as being un-checked, and I
window, and afterwards I had the problem I’m describing now.
I’ve tried removing and reinstalling QGis and GRASS and I cannot seem to
All the best.
www.faunalia.eu
grass-user mailing list
