Hello,
I’ve installed GRASS 7.8.3 on Ubuntu 20.10 (groovy) and when I try to install my own python script, the message is :
Fetching <r.wtg> from </media/zephyr/ress/informatique/scripts/grass/scripts/r.wtg> (be patient)…
Compiling…
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visibility.threshold: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visibility.conv: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.surround: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visibility: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.intervisibility: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visual.area: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visual.cone: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.visual.competition: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.horizontal.visibility: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.terrain.vertical.angle: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.terrain.horizon: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.pit2hwtg: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.overhang: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/v.wtg.visibility.what: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/r.wtg.series: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/v.wtg.surround: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/g.wtg.listfromtable: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/v.wtg.drawline: not found
/bin/sh: 1: /tmp/grass7-geophom-78286/tmp1tw0ncyb/r.wtg/scripts/v.wtg.transect: not found
Installing…
Updating private addons metadata file…
WARNING: No addons metadata available. Addons metadata file not updated.
Installation of <r.wtg> successfully finished
All files are well copied in /home/me/.grass7/addons/scripts
And when i want to execute one of them (here r.wtg.visibility), I get :
File “/usr/lib/grass78/etc/python/grass/script/task.py”,
line 473, in get_interface_description
p = Popen([cmd, ‘–interface-description’], stdout=PIPE,
File “/usr/lib/grass78/etc/python/grass/script/core.py”,
line 63, in init
subprocess.Popen.init(self, args, **kwargs)
File “/usr/lib/python3.8/subprocess.py”, line 854, in
init
self._execute_child(args, executable, preexec_fn, close_fds,
File “/usr/lib/python3.8/subprocess.py”, line 1702, in
_execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError
[Errno 2] No such file or directory: ‘r.wtg.visibility’
During handling of the above exception, another exception
occurred:
File “/usr/lib/grass78/gui/wxpython/gui_core/prompt.py”,
line 272, in OnItemSelected
self.cmdDesc = gtask.parse_interface(cmd)
line 522, in parse_interface
tree = etree.fromstring(get_interface_description(name))
line 501, in get_interface_description
raise ScriptError(_(“Unable to fetch interface description
for command ‘<{cmd}>’.”
grass.exceptions
ScriptError
Unable to fetch interface description for command
‘<r.wtg.visibility>’.
Details: <[Errno 2] No such file or directory:
‘r.wtg.visibility’>
If i rename a script with .py, I can execute it from the menu File>execute script
I have two other Grass (7.9) on Debian Buster and it works fine…
The $GRASS_ADDON_BASE = /home/me/.grass7/addons
The $GRASS_ADDON_PATH = /home/me/.grass7/addons/scripts
Do you have any idea that problem ?
Thank you for your help.
Frank David
