Hi GRASS list,
I recently upgraded to 7.0.4 and can no longer open NetCDF files. I re-installed several components at the time of the upgrade, so this may be a gdal or other software error too. I'm not sure how to debug this, and hope someone here can help.
I try to load a variable from a NetCDF file with the following command, which worked last time I ran it in 7.0.3:
r.in.gdal input=NETCDF:foo.nc:var output=ar
I now get the following error:
ERROR 4: No such file or directory
ERROR: Unable to open datasource
<NETCDF:foo.nc:var>
However, "foo.nc" does exist in the current folder. Read/write permissions is not a problem either. This could be external to GRASS? Part of a gdal compilation issue? But "gdalinfo foo.nc" doesn't have any issues.
I'm on OS X and installed grass 7.0.4 via homebrew, which automatically installed gdal-2.0 for me as a dependency, just as it did for 7.0.3 where everything worked.
Any hints will be much appreciated.
-k.
On 2016-08-15 at 22:07, Ken Mankoff <mankoff@gmail.com> wrote:
Hi GRASS list,
<NETCDF:foo.nc:var>
This is fixed by compiling gdal 1 with "--with-complete" and then grass with gdal1 not the default gdal2:
brew install gdal --with-complete
brew install grass-70 --with-netcdf --with-gdal-1
-k.
Hi GRASS list,
<NETCDF:foo.nc:var>
Glad you found a solution. Please consider to add some notes here:
https://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
