[GRASS-user] can't use r.recode from standart GUI
I'm trying to use the r.recode fonction via the GUI (raster, change categories values.../recode categories using rules). When I launch the fonction, proper window opens, but when I click run, a terminal window strart to open and close very quickly. Hence, I can't notify new values to use for recoding the raster map. If I use the r.recode fonction from the Grass terminal, everything is working properly...
Does someone have any tip for this problem?
Thanks
Nicolas
