[GRASS-user] Categories in new layers of vector maps
I am slightly confused about creating new layers for vector maps and adding a category value.
I want to add a layer and subsequently I want to use v.what.rast to query a raster map and update
that layer. Hence, I need categories in the new layer. However, it seems that adding a new table and connect it to a specific layer (v.db.addtable) does not create/update the category column (in GRASS 71, trunk):
Here an example for the NC-dataset:
v.db.addtable map=firestations@PERMANENT layer=2
DB settings already defined, nothing to do
Reading features…
Updating database…
0 categories read from vector map (layer 2)
0 records updated/inserted (layer 2)
And when I try to manually update the category I am also not successful:
v.to.db map=firestations@PERMANENT layer=2 option=cat columns=cat
Reading features…
Updating database…
Maybe I just got something wrong?
The map “firestations@PERMANENT” has categories (stored in layer 1)
v.category input=firestations@PERMANENT option=report
Layer/table: 1/firestations
type count min max
point 71 1 71
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 71 1 71
v.category complete. 0 features modified.
Any suggestions?
best,
Johannes
Hi Johannes,
On Mon, Oct 13, 2014 at 10:18 AM, Johannes Radinger
<johannesradinger@gmail.com> wrote:
The map "firestations@PERMANENT" has categories (stored in layer 1)
type count min max
point 71 1 71
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 71 1 71
Any suggestions?
you should use the v.category to copy the categories from layer1 to layer2.
Pietro
Johannes Radinger wrote
adding
a category value.
a
Reading features...
Updating database...
Reading features...
type count min max
point 71 1 71
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 71 1 71
Any suggestions?
best,
Johannes
grass-user mailing list
grass-user@.osgeo
a possible workflow (but maybe not the only one):
g.copy vect=hospitals@PERMANENT,myhospitals
v.db.addtable map=myhospitals@testnewlayer table=myhospitalslayer2 layer=2
Lese Objekte...
Aktualisiere die Datenbank...
0 Kategorien gelesen von der Vektorkarte (Layer 2).
0 Datensätze aktualisiert/eingefügt (Layer 2).
v.category --verbose input=myhospitals@testnewlayer layer=2
output=myhospitals2layers option=add
Using native format
Verarbeite Objekte...
Kopiere Attributtabelle(n)...
Erstelle Topologie für die Vektorkarte <myhospitals2layers@testnewlayer>...
Registriere Primitive...
160 primitives registered
160 Vertices registriert
Erzeuge Flächen...
0 areas built
0 isles built
Füge Inseln hinzu...
Füge Zentroide hinzu...
Die Topologie wurde erstellt.
Anzahl der Knoten: 0
Anzahl der Primitive: 160
Anzahl der Punkte: 160
Anzahl der Linien: 0
Anzahl der Grenzen: 0
Anzahl der Zentroide: 0
Anzahl der Flächen: 0
Anzahl der Inseln: 0
v.category komplett. 160 features modified.
v.to.db map=myhospitals2layers@testnewlayer layer=2 option=cat columns=cat
Lese Objekte...
160 Kategorien gelesen von der Vektorkarte (Layer 2).
160 Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion
der Tabelle.
160 Datensätze aktualisiert/eingefügt (Layer 2).
v.db.addcolumn --quiet map=myhospitals2layers@testnewlayer layer=2
columns=testquery double
v.category input=myhospitals2layers@testnewlayer option=report
v.category komplett. 0 features modified.
Layer/Tabelle: 1/myhospitals2layers_hospitals
Typ Anzahl Min Max
Punkt 160 1 160
Linie 0 0 0
Grenze 0 0 0
Zentroid 0 0 0
Fläche 0 0 0
Oberfläche 0 0 0
Kernel 0 0 0
Alle 160 1 160
Layer/Tabelle: 2/myhospitals2layers_myhospitalslayer2
Typ Anzahl Min Max
Punkt 160 1 160
Linie 0 0 0
Grenze 0 0 0
Zentroid 0 0 0
Fläche 0 0 0
Oberfläche 0 0 0
Kernel 0 0 0
Alle 160 1 160
g.region -p -a --verbose rast=elevation@PERMANENT align=elevation@PERMANENT
v.what.rast --verbose map=myhospitals2layers@testnewlayer layer=2
raster=elevation@PERMANENT column=testquery
Reading features from vector map...
WARNING: 158 Punkte außerhalb der Region wurden übersprungen.
Update vector attributes...
2 Kategorien aus dem Vektor geladen.
160 Kategorien aus der Tabelle geladen.
0 Kategorien des Vektors fehlen in der Tabelle.
v.what.rast komplett. 2 records updated.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Categories-in-new-layers-of-vector-maps-tp5167141p5167191.html
adding
a category value.
a
Reading features...
Reading features...
type count min max
point 71 1 71
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 71 1 71
Any suggestions?
best,
Johannes
grass-user@.osgeo
one possible workflow (but maybe not the only one):
Lese Objekte...
Using native format
Erzeuge Flächen...
0 areas built
0 isles built
Lese Objekte...
der Tabelle.
Typ Anzahl Min Max
Punkt 160 1 160
Linie 0 0 0
Grenze 0 0 0
Zentroid 0 0 0
Fläche 0 0 0
Oberfläche 0 0 0
Kernel 0 0 0
Alle 160 1 160
Typ Anzahl Min Max
Punkt 160 1 160
Linie 0 0 0
Grenze 0 0 0
Zentroid 0 0 0
Fläche 0 0 0
Oberfläche 0 0 0
Kernel 0 0 0
Alle 160 1 160
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Categories-in-new-layers-of-vector-maps-tp5167141p5167194.html
On 13/10/14 10:18, Johannes Radinger wrote:
Have you read the section "Vector object categories and attribute management" in the vector processing intro: http://grass.osgeo.org/grass64/manuals/vectorintro.html
If that is not clear, we should probably try to enhance it.
Moritz
