Hi List!
I'm facing some problems while printing a vector map. I have a map with a polygon grid with a number in one column (this is a count of points which lies within each grid cell).
I would like to print this vector map with a colour gradient e.g. from white to blue. The categorisation should be done automatically with a specific mode (e.g. natural breaks, quantiles) and the number of classes has to be customisable.
Is there is possibility/function which does this with a vector layer as input?
I have found a workaround with raster maps, but even there was no possibility for an automatic classification (at least I didn't find).
Thanks in advance!
On 23/01/12 15:18, Steffen John wrote:
Hi List!
input?
Try d.vect.thematic, possibly after having run v.class for finding class breaks if you don't like the ones proposed by d.vect.thematic.
Moritz
