I need to calculate some Central tendency quotients like Mean Center,
Weighted Mean Center and Standard Distance. Are there any tools to implement
it with Grass Gis (or other OS software)? It may be easy to extract the
point coordinates of a shp and make the calculations but I'd like to know if
there is any build in tool in Grass GIS or other OS soft.Thanks, Leonidas
View this message in context: http://n2.nabble.com/Central-tendency-with-Grass-tp2408175p2408175.html
Leonida,
could you be a bit more specific?
You need to upload in specific points values like mean, weighted mean,
standard distance, etc? If yes, how big should be your radius for each
point, i.e. how big will be your circle from which the numbers will
come?
There are lot's of tools in GRASS and you just need to synthesise them
to find the solution you need.
Cheers, Nikos
Niko,
I need a tool to find spatial mean (mean center), weighted mean center, and
standard distance.
You can take a look in this article to understand what I mean (in greek):
http://www.demography-lab.prd.uth.gr/DDAoG/edu/case/2/kentro-v.htm
So, I'm looking for a tool that I'll define as input a point shapefile (or
vector map in grass) with a field for weight values(for weighted mean
center) and then, as an output, I'll get a shapefile with one point for
spatial mean, another shapefile with a point as the weighted mean center and
finally a shapefile with a polygon representing the standard distance as
circle.Thank you for the interest, Leonidas
implement
if
there is any build in tool in Grass GIS or other OS soft.Thanks, LeonidasLeonida,
come?There are lot's of tools in GRASS and you just need to synthesise them
to find the solution you need.Cheers, Nikos
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/Central-tendency-with-Grass-tp2408175p2425545.html
On Wed, 2009-03-04 at 13:23 -0800, leonidas wrote:
Niko,
standard distance.
If you happened to have a Windows machine (I don't think it runs on
Linux)I would try this one http://www.icpsr.umich.edu/CRIMESTAT/
>> implement
>> if
> Leonida,
> come?
> Cheers, Nikos
Linux)I would try this one http://www.icpsr.umich.edu/CRIMESTAT/Cheers
Thank you, I'll try it. I also found that for R:
http://cran.r-project.org/web/packages/aspace/index.html
View this message in context: http://n2.nabble.com/Central-tendency-with-Grass-tp2408175p2430055.html
Well, CRIMESTAT seems to work with WINE on Ubuntu 8.10. I start it without
any errors (but only started, didn' try to load data and perform analysis!).
View this message in context: http://n2.nabble.com/Central-tendency-with-Grass-tp2408175p2430128.html
