I have many vectors with tables and now I want to change my database from sqlite to pgsql.
I ran db.connect. And now I need to copy all the tables from sqlite to pgsql.
Is there an easy way to do that?
Thanks.
Pablo Torres Carreira
Thanks.
Once you’ve set the database connection params, then g.copy will create a new vector with the attributes pushed into the new database. So you could loop thru all vectors something like:
for v in g.mlist vect
; do
g.rename vect=$v,$v_sqlite # rename to temporary name
g.copy vect=$v_sqlite,$v # copy back to original name, but pgsql tables will be created
done
If everything looks good, then you can remove all the vectors *_sqlite:
g.remove vect=g.mlist vect sep=, pat="*_sqlite"
Micha Silver
Arava Development Co. +972-52-3665918
[http://surfaces.co.il](http://surfaces.co.il)
