Hi:
I want to know if I can change my the grass location in the command line?
I know the g.mapsets command to change mapset,how about the location?
Hi:
command line?I know the g.mapsets command to change mapset,how about the
location?
g.mapset location=
(no "s")
do so at your own risk though, check that temporary files are removed
and you probably don't want to have the GUI running.
if possible it is much cleaner to exit grass and restart in the new
location.
Hamish
Thanks
Does the gisrc file (.grassrc6) work for just one user? I mean if more than one user use the grass , should I create a .grassrc6 which contain a new location and mapset for each user?
On Sat, Feb 27, 2010 at 11:43 AM, maven apache <apachemaven0@gmail.com> wrote:
Thanks
Are they real or Web users?
Perhaps take a look at
http://grass.osgeo.org/wiki/Parallel_GRASS_jobs
2010/2/27 Markus Neteler <neteler@osgeo.org>
Thanks
location and mapset for each user?Are they real or Web users?
http://grass.osgeo.org/wiki/Parallel_GRASS_jobsMarkus
Web users, they call the grass installed in the server to do some geo-process, they may call it at the same time.
