grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
grass-user-request@lists.osgeo.orgYou can reach the person managing the list at
grass-user-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."Today's Topics:
1. Re: Extracting line heights from 3d vectors (Moritz Lennert)
2. Re: Extracting line heights from 3d vectors (Nick Cahill)
3. Re: Extracting line heights from 3d vectors (Vincent Bain)
4. Re: Extracting line heights from 3d vectors (Nick Cahill)
5. Re: [Fwd: grass-related failure when building qgis_0_11]
(Markus Neteler)
6. Re: [Fwd: grass-related failure when building qgis_0_11]
(Nikos Alexandris)
7. change projection, project vector file (Stefanie Obmann)
8. Re: maximum zoom-in reached (H.S.Rai)----------------------------------------------------------------------
Message: 1
Date: Sat, 29 Nov 2008 18:04:03 +0100
From: Moritz Lennert <mlennert@club.worldonline.be>
Subject: Re: [GRASS-user] Extracting line heights from 3d vectors
To: Nick Cahill <ndcahill@wisc.edu>
Cc: grass-user@lists.osgeo.org
Message-ID: <49317603.40509@club.worldonline.be>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedOn 28/11/08 19:57, Nick Cahill wrote:
I have a series of contour vector maps imported from a CAD program
(Microstation). The CAD maps were in 3d, and the 3d information was
successfully imported into GRASS, so the vectors have line heights as
well as length, etc. Now I need to export these into shapefiles. When I
do this, all the other useless CAD data like line color, style, weight,
etc. is exported as attributes in the .dbf file, but line height is not
-- it is not a field in the mySQL database but is part of the geometry
of the line, if I understand what's going on here correctly. Is there a
way to transfer line height into the attribute table so I can access and
export it?
v.to.db option=coor ?Moritz
Message: 2
Date: Sat, 29 Nov 2008 11:18:21 -0600
To: grass-user@lists.osgeo.org
Message-ID: <47398522-0CA3-43B1-9101-E9A210DF9B32@wisc.edu>
Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yesDear Hamish,
Yes, the lines are absolutely horizontal - every point has the same
elevation. I tried v.to.db before writing to the list. But v.to.db
only has options to upload the following values: cat, area, compact,
perimeter, length, count, coor, start, end, sides, query, slope. A
v.what query on a typical line has:Map: con10
Mapset: PERMANENT
Type: Line
Line: 2110
Length: 432.740896
Line height: 200.000000
Layer: 1
Category: 2110Driver: mysql
Database: sardisutm
Table: con10
Key column: cat
cat : 2110
type : 4
level : 3
graphicgroup : 0
colorindex : 3
weight : 0
style : 0
entitynum :
mslink :
text :I tried just typing "line height" into v.to.db anyway, but got a
predictable errorERROR: value <line height> out of range for parameter <option>
Legal range:
cat,area,compact,perimeter,length,count,coor,start,end,sides,query,slopeI just figured out that you can get the information from v.out.ascii,
and then discard the coordinates and such; but it seems like there
should be an easier way of accessing this information.Many thanks!
Nick Cahill
On Nov 28, 2008, at 7:14 PM, Hamish wrote:
program (Microstation). The CAD maps were in 3d, and the 3d
information was successfully imported into GRASS, so the
vectors have line heights as well as length, etc. Now I need
to export these into shapefiles. When I do this, all the
other useless CAD data like line color, style, weight, etc.
is not -- it is not a field in the mySQL database but is
part of the geometry of the line, if I understand what's
going on here correctly. Is there a way to transfer line
height into the attribute table so I can access and export
it? Many thanks,
v.db.addcol + v.to.db ?
note that unless lines are perfectly horizontal (eg elevation
contours)
you can not assign a single elevation value to a line's attributes (as
each vertex will have its own value, and the attribute is associated
with
the line as a whole), so I would expect in general for it to refuse
to try.as for 3D shapefile export, ummm... check the wiki, help pages, and ML
archives. It rings a bell but I've no idea how.Hamish
Message: 3
Date: Sat, 29 Nov 2008 18:22:22 +0100
Message-ID: <1227979342.6271.5.camel@vincent-desktop>
Content-Type: text/plain; charset=utf-8If you are sure lines are horizontal, then you can copy coordinates of
the from-node (or the to-node, anyway) of each line to your table.Vincent.
Le samedi 29 novembre 2008 à 11:18 -0600, Nick Cahill a écrit :
Dear Hamish,
Mapset: PERMANENT
Type: Line
Line: 2110
Length: 432.740896
Layer: 1
Database: sardisutm
Table: con10
Key column: cat
cat : 2110
type : 4
level : 3
graphicgroup : 0
colorindex : 3
weight : 0
style : 0
entitynum :
mslink :
Legal range:
Nick Cahill
it? Many thanks,
contours)
with
http://lists.osgeo.org/mailman/listinfo/grass-user------------------------------
Message: 4
Date: Sat, 29 Nov 2008 11:25:01 -0600
To: hamish_b@yahoo.com
Message-ID: <292E9427-36CB-4AD2-992F-769E4069D57F@wisc.edu>
Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yesAh, right you are -- I added columns x,y,z to the table and then ran
v.to.db option=start columns=x,y,z and it worked perfectly. Many thanks!Nick Cahill
it? Many thanks,
contours)
with
Message: 5
Date: Sat, 29 Nov 2008 18:26:40 +0100
Subject: Re: [GRASS-user] [Fwd: grass-related failure when building
qgis_0_11]
To: "Nikos Alexandris" <nikos.alexandris@felis.uni-freiburg.de>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Message-ID:
<86782b610811290926w5233f1a6y24808bef903884c7@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1On Mon, Nov 24, 2008 at 6:24 PM, Nikos Alexandris
<nikos.alexandris@felis.uni-freiburg.de> wrote:
---------- Forwarded message ----------
From: Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
To: grass-dev@lists.osgeo.org
Date: Mon, 24 Nov 2008 07:49:10 +0100
Subject: grass-related failure when building qgis_0_11
Hi all! I get this error when building qgis 0.11 from source. I've read
the http://trac.osgeo.org/grass/ticket/364 ticket. Is it really fixed?This problem does not occur when building qgis preview version.
[ 71%] Building CXX object
src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o
/usr/local/grass-6.4.svn/include/grass/Vect.h: In static member function
'static int QgsGrassProvider::openMap(QString, QString, QString,
QString)':
/usr/local/grass-6.4.svn/include/grass/Vect.h:197: error: too many
arguments to function 'int Vect_build(Map_info*)'
/usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1040: error: at this point in file
/usr/local/grass-6.4.svn/include/grass/Vect.h: In member function 'bool
QgsGrassProvider::closeEdit(bool)':
/usr/local/grass-6.4.svn/include/grass/Vect.h:199: error: too many
arguments to function 'int Vect_build_partial(Map_info*, int)'
/usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1495: error: at this point in file
/usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1496: error: at this point in file
make[2]: ***
[src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o] Error
1
make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
make: *** [all] Error 2
I have backported the needed GRASS provider changes from QGIS-trunk
to 0.11.svn and sent to the QGIS people for integration.Markus
Message: 6
Date: Sat, 29 Nov 2008 21:16:57 +0100
qgis_0_11]
Message-ID: <1227989817.30082.0.camel@vertical>
Content-Type: text/plainOn Sat, 2008-11-29 at 18:26 +0100, Markus Neteler wrote:
QString)':
make[2]: ***
1
Thanks to Markus it works nowNikos
Message: 7
Date: Sat, 29 Nov 2008 23:20:55 +0100
Subject: [GRASS-user] change projection, project vector file
Message-ID: <20081129222055.237170@gmx.net>
Content-Type: text/plain; charset="iso-8859-1"Dear users
I can't project my map in a geographic projection location right into a location with austrian lambert conic conform projection. If I try it with v.proj GRASS just imports the ID-column twice and no other columns f.e. coordinates, values...
Should I use another command?
I would be very greatful for any help!!!
thanks,
stef
Stef,
Use v.transform to reproject the vector from the old location into the
new location.
Richard
